964 motor low point?
Will a 964 motor sit flat on its stock exchangers, or is the case split line lower? It looks lower is why I ask. If so, safe to set it on a cart with one heat exchangers acting as an outrigger?
Thanks! |
I have put mine on a cart sitting on the heat exchangers. No problem.
Does it sit flat, or slightly to one exchanger?
IIRC it sat flat.
Personally, I always 2x4s or something to support the weight of the motor and use the heat exchangers for balance.http://forums.pelicanparts.com/uploa...1582479066.jpg
Thanks! |
Mines (the pic) a 3.3 So, probably a bit different. I should have read the posts more carefully.
It sounds like the 964 hits the case first. Should be fine. |
| All times are GMT -8. The time now is 10:51 AM. |
