Strut installation
Hi All!
I'm currently doing a full restoration on a -71T.
Yesterday I installed the front struts. It is a standard setup with new Bilstein struts and new ball joints.
They are now in place but I've got to tell, it was a struggle! Lining up the pin and strut was not just a slide in... It called for some serious persuasion.
For the next time... what is the secret getting these in place? Or is it always a really tight fit?
Appreciate all input.
Jörgen Forssling
Gothenburg
SWEDEN
Old 02-25-2020, 11:27 PM
Flojo's Avatar
what exactly made you struggle?
getting the joint pin in or the retainer pin to lock the strut?
it is designed not to gave struggle.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-26-2020, 03:21 AM
It was getting the ball joint pin (with the cut out) into the strut.
//Jörgen
Old 02-26-2020, 03:24 AM
Flojo's Avatar
and the strut itself was loose? not attached to tie rod or upper mount?
Old 02-26-2020, 03:40 AM
The ball joint is mounted on the wishbone, which is on the car. New strut inserted in top mount. Not attached to tie-rods. I tried to align the ball joint pin that goes into the base of the strut. I finally got it in but it was tough.
//Jörgen
Old 02-26-2020, 03:47 AM
Old 02-26-2020, 03:51 AM
H-viken's Avatar
It should be that tough
Did you do a “dry run “ when the parts were loose?
The times I’ve done it I have had the strut loose and not attached at the top. Maybe this simplifies it?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 02-26-2020, 05:42 AM
No unfortunately I didn't do that. Makes me feel better that you also had some effort to get them in place.
Thanks,
Jörgen
Old 02-26-2020, 05:45 AM
Install the strut onto the ball joint first, then lift the assembly to attach to the top mount. If I'm reading correctly you did that in reverse.
Old 02-26-2020, 06:07 AM
You are right, I did the opposite. I was afraid not being able to get in the top mount otherwise.
Now I know for the next time
//J
Old 02-26-2020, 06:12 AM
H-viken's Avatar
Thanks,
Jörgen
sorry, typo. it should have said "it SHOULDN'T be that tough"
911E Coupe -70
Old 02-26-2020, 11:20 AM
OK, now they're in place anyway...
//J
Old 02-26-2020, 10:42 PM
Flojo's Avatar
again, this should be an easy job, it's designed that way.
this is why I asked HOW the assembly was, if attached to top mount or tie rod.
But even then, it is designed to be swapped when strut attached to car to avoid later alignment.
so either this was a bad aftermarket part with bad measured pin size or something was stuck/blocking the pin insert inside the strut base.
I've done both, swap on bench, swap on car, no issues.
Old 02-27-2020, 05:22 AM
I understand, and that's what makes me worry... The strut is Bilstein and the ball joint is Lemförder, both respected brands. However, as said, now it's in place and I hope I don't have to service either of them anytime soon.
//Jörgen
Old 02-27-2020, 05:28 AM
not to highjack the thread but I have the whole front suspension dropped right now and all things replaced except the ball joints. Should I attempt to break loose with it back in the car or out of the car? Anyone have any preferences? I know it's not a fun job.
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle
Instagram: @pdklol
Old 02-27-2020, 09:09 AM
