Condensation on oil fill cap of a 911 SC.
After a very mild winter in this part of Montana and more in town driving, I am finding evidence of moisture on my oil fill cap. All the hoses that have anything to do with oil and crankcase vapor seem secure. Is this a problem? Normally when I have put the car on the highway and let the left foot down, this disappears. 280 miles on Friday did not do much.
Old 02-23-2020, 08:27 AM
PRO Motorsports
Tyson Schmidt's Avatar
Very normal. It’ll take elevated oil temps to get rid of it all and that may be hard to do this time of year in your region.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-23-2020, 08:39 AM
How warm is the oil getting?
Old 02-23-2020, 09:59 PM
Targa_PB_78_SC
mike sampsel's Avatar
Yes, short in town driving will increase the moisture from condensation. It’s a reason you want the occasional longer trip to get things warm enough to evaporate all the water.
BareRearedRookie
Old 02-24-2020, 04:08 AM
Thanks to all
It is great to get some reassurance. Love affair of 21 years and I want to keep her happy.
Old 02-24-2020, 01:18 PM
MichaelSJackson's Avatar
You don't want to leave that condensation in there. Take her out for a longer drive. Get her hot. Then park her.
Old 02-25-2020, 11:22 AM
I have the same issue here in central Oregon with my 84 3.2. I try to drive it hard a least once a week and long enough to get hot. Dont know if this helps but when I park in garage I pull the cap and let it vent for a while thinking it may release a little more moisture in the oil.
John S
84 Euro 911
C300
Old 02-25-2020, 12:54 PM
That mayonnaise-consistency material is historically called sludge. It’s usually indicative of not bringing the engine up to operating temps often enough and/or not changing the oil often enough to rid the engine of that buildup. Excessive amounts can block oil passages and inhibit heat transfer.
It’s just some evidence there may be additional areas of that same buildup inside the engine.
The solution is to drive long enough to bring the entire lube system up to temp. before shutting down.
Sherwood
Old 02-25-2020, 04:00 PM
Functionista
manbridge 74's Avatar
Another solution for short trippers/cold weather guys is to block the grille off maybe 90%. Gets the thermostats opened up enough to send oil to the front cooler etc. Fab one up that’s quickly removed, the suction helps in holding it down.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-25-2020, 05:44 PM
