Burgsailor
What is this - 82 sc
Replacing the fuel filter I noted pictured piece was broken. Mounts just below the filter. Have no earthly what it is/does/functions. Appreciate any help. Thank you.
El Duderino
No picture.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Can you try again with the picture please
Ox sensor connector? They tend to get brittle and break with age. Are you running a sensor?
Walt 82SC 3.0 81SC 3.6 |
Burgsailor
Strictly stock. No aftermarket pieces. It’s an ox sensor? Haven’t chased the wires to see if they feed to any exhaust ports but a quick look doesn’t have me thinking it’s going to the exhaust.
Burgsailor
El Duderino
If you’re talking about the broken orange connector that is indeed the OXS sensor connector. There is a guy here with the handle Louie_85 (maybe no underscore?). He makes replacement connectors as they are no longer available.
You can send him a Private Message (PM)
El Duderino
Forgot to add... totally common failures. Those things disintegrate with age.
Flat Six
O2 sensor plug
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
If the connection is good, the broken plastic part doesn't matter.
Or simply add a new connector the the wire like a "superseal" one.
Which is btw much more comfortble for pullin and pluggin than the original.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Burgsailor
You guys rock. Appreciate the assessment and gouge. Copy all.
Btw - a chuckle for the wrench turners: “honey - I’m just going to go swap a fuel filter - 30 minutes I’ll be back.” 5 hours later the scene.
