14.7-15.0 AFR targets.
I've seen lots of ignition maps shared around different threads but thought it would be most helpful to have 1 thread to house the lot of them.
if you feel like contributing, please post your map and include motor specs (2.7L, 3.0L, 3.2L SS, 3.2L LS, CIS dome, RSR dome, etc....) and thanks for embracing the open-source mentality!
Disclaimer - no one besides yourself shall be responsible for engine damage from using a shared ignition map. Know well enough what you are doing/risking before you go and try someone else's ignition settings.
Below is my ignition map. Specs in the header of the image but i should mention its single plug too. Most of my light throttle cruising cells are paired with 14.7-15.0 AFR targets.
Old 02-27-2020, 06:21 AM
