What is this piece?
Forgive me for any stupid questions but I am not real familiar with the air cooled Porsche engine just yet. This was my Dad's car that I inherited from him and I fully intend to keep it, maintain it, and love it but i need some help. I can wrench fairly well but I am not certain as to what parts are. I am told this car has a 3.4L engine and I have receipts that say so but I believe it is actually a 3.2 that was bored to a 3.4
I am going to change the plugs, wires, and cap and rotor this weekend and to ge tot eh left side plugs I have to remove this piece. What is it and does it simply unbolt and come out? |
I'm good with tools.
Pictures would be helpful.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Thats a "helper" blower that increases air flow for cabin heat and defrost. If you research "heat backdate" you'll find many people remove the extra blowers. The original Porsche engine design relied solely on the large engine fan for all cabin heat, worked quite well also...
If you simply remove that blower without completing the rest of the "backdate" you will lose all (most?) heat and defrost.
1978 SC Targa |
That blue box on your AC stand is something you should research further. It's a Jacobs Electronics "Omni Pak" aftermarket ignition system. Very odd to see on a 3.2 as the ignition system is controlled by the DME computer under drivers seat.
If your having running issues (think you mentioned you were) I'd revert all the ignition system back to stock as a first start. The 3.2 stock ignition is quite robust and works well.
1978 SC Targa |
I started to comment on this too. I haven't seen one of those Jacobs boxes since my fox body mustang days in the mid to late 80's.
I dont think the car is stock. I have a packet of receipts totaling over $20k and it shows that the engine was upgraded to a 3.4L with Carrera Racing cams, turbo high volume oil pump, stainless steel exhaust, modified fuel enrichment chip, dilivar head studs, 2 timing chains. Or at least that what the receipts say. Im kind of working in the blind here because my Dad didnt really tell me too much about the car prior to his passing. |
If the rear heater fan is not working, absent, the front two fans won't work. I am sure there is a work around for that, just never tried it. Bob
You can remove the duct with 2 screws, don’t drop them!
Wow. There is a lot going on with that engine just from the pic. Hot air socket duct replaced with flexible hose, painted / powder coated intake manifold, Jacobs ignition box, what appears to be a K&N air filter element in the airbox, etc.
Was the 3.4 build done locally? Has the vehicle passed CA emissions? You might consider having one of the local air cooled specialists giving the car a once over as a launch pad for your intended ownership / maintenance / love affair. Mirage International (my '87 is currently there undergoing a 3.4 build) or Black Forest Automotive are two great options. I'd love to see the car (I'm in Encinitas / Carlsbad and, pre Coronapocalypse, normally go to Rancho Santa Fe Cars & Coffee), perhaps someday.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
If not, take them to a local garage of your choice and have them review the receipts and inspect the car. Hopefully they can tell you what you have an how to proceed. While many here are staunch DIY types, I belong to the school that having a partnership with a trusted mechanic is a better way to go.
