Help with Shock Part Numbers
Hi,
I was hoping you could help out with confirming if I have purchased the correct parts for my car. I have ordered and received the following: Bilstein 24-001694 I believe these are the rear shocks Bilstein 34-001127 I believe these are the front strut inserts I have a 1977 911 Targa S and I think currently that car has Bilstein front struts and I think the ones I have ordered are fore Boge Inserts. Can someone confirm that before I try to install them or send them back :) Also, can you share your thoughts on whether or not these are appropriate? I was trying to buy the Bilstein HD shocks, did I mess up? I ordered them from a Canadian supplier, not wanting to mess with Duty and/or Exchange and I'm concerned I messed up the order. Thanks |
If I look at my current strut, it is green and has the "C" pin at the bottom of the strut.
I think that means that I have Bilstein Struts and I think I've ordered the inserts for Boge :( |
1127 does show as being for Boge equipped cars, not for Bilstein strut housings. The numbers you list are the standard HD parts.
| All times are GMT -8. The time now is 01:33 PM. |
