Help with Shock Part Numbers
Hi,
I was hoping you could help out with confirming if I have purchased the correct parts for my car. I have ordered and received the following: Bilstein 24-001694 I believe these are the rear shocks Bilstein 34-001127 I believe these are the front strut inserts I have a 1977 911 Targa S and I think currently that car has Bilstein front struts and I think the ones I have ordered are fore Boge Inserts. Can someone confirm that before I try to install them or send them back Also, can you share your thoughts on whether or not these are appropriate? I was trying to buy the Bilstein HD shocks, did I mess up? I ordered them from a Canadian supplier, not wanting to mess with Duty and/or Exchange and I'm concerned I messed up the order. Thanks |
If I look at my current strut, it is green and has the "C" pin at the bottom of the strut.
I think that means that I have Bilstein Struts and I think I've ordered the inserts for Boge
Functionista
1127 does show as being for Boge equipped cars, not for Bilstein strut housings. The numbers you list are the standard HD parts.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
