It's a 914 ...
Does this 915 dogring have the backcut?
It's been known for a while that the R&S dog rings make in the last years didn't have the correct angled backcut on the dog teeth. I have a dog ring that is of unknown age, so I want to make sure it has the backcut before using it. I think it does. What say y'all?
Thanks ...
Ask Roger Brown at CMS
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet |
(man/dude)
At a glance, it looks like it does, but if you throw a synchro ring on it, it will be immediately apparent. This one does have it:
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
isn`t the top picture 2nd gear and the next pic with the synchro 1st gear??
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
(man/dude)
I think?
nope ...the 1st gear has a special synchro ring with the groove in it..look 2nd does not
Ivan 1st ![]() 2nd
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 02-29-2020 at 02:11 PM.. |
(man/dude)
LOL. Ok, you got me, but the back - cut is the same, right? I was just trying to answer the OP's question by showing him a synchro, and how it rests in the dog teeth.
Under the radar
And you can check the spec like this.
(man/dude)
Here's a pic of 2nd, for reference.
Jonny 042: GREAT pictures!
Keep the Shiny Side UP! Pete Z. |
I wouldn't measure the installed dimension until fully assembled, in particular with the snap ring in place. Also I measure at 90 and 270, if you consider the gap in the ring to be 0.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
