Using back-nut spanner to remove Boge suspension shocks on torsion-bar 911
Not sure anyone has done it in this way before or I just missed the old post.
I tried the pipe-wrench method, it didn't work, plus it damaged the shock cover. Then I found there is a back-nut spanner sitting in my plumbing stuff, and it just fit the Boge shock top cover perfectly. It doesn't have the size on it but I think it's 27mm-32mm (standard UK plumbing size). Sacrificed a socket to make an impact drive connector, a 10mm bolt + nut, job done. BTW, mine is 3.2 Carrera, older 911 may need a smaller spanner? https://thumbs2.imagebam.com/a8/f1/1...1335963268.jpg https://thumbs2.imagebam.com/ce/a7/6...1335963274.jpg https://thumbs2.imagebam.com/6f/4d/3...1335963275.jpg https://thumbs2.imagebam.com/a4/65/5...1335963282.jpg https://thumbs2.imagebam.com/3b/80/8...1335963286.jpg https://thumbs2.imagebam.com/12/b4/4...1335963297.jpg |
The pipe wrench worked perfectly for removing mine a few weeks ago and I used a chisel and hammer to tap on the new ones that came with my bilstein inserts.
Good idea. I've used a strap wrench several times, it doesn't mar up the metal but probably wouldn't be enough if the cap is rusted on.
| All times are GMT -8. The time now is 07:03 PM. |
