-   -   Brake Lines (http://forums.pelicanparts.com/porsche-911-technical-forum/105416-brake-lines.html)
zephog 04-07-2003 07:28 AM
Brake Lines
Is there any problems with swaping the hard plastic brake lines that go from the brake resv. to the master cylinder? I was thinking of removing the plastic tubes and just using rubber brake lines instead. Also, can someone take a photo of how those plastic lines feed from the mc up through the body to the brake resv. I looked all over the bottom of my car and cannot figure how these lines are suppossed to feed through.
Thanks in advance..
Greg
Neilk 04-07-2003 09:42 AM
I was thinking about pulling the brake lines out when I replaced my MC, but it looked like I would need to remove the fuel tank to thread the lines back through. I wouldn't want rubber lines feeding the MC. If the lines were to get pinched somehow, it might affect your braking ability.
BK911 04-07-2003 09:56 AM
Those hard plastic lines go from the MC, up through the cabin by your feet, to the reservoir.
zephog 04-07-2003 11:09 AM
Well here is the problem, I put a new full pan in (front bumper to rear seats all one piece) and there does not appear to be a place in the pan to feed the line through. Do i need to cut my own holes? Can someone shoot me a picture?
zephog 04-07-2003 01:34 PM
Is this where the feed line (see right) should feed through?http://forums.pelicanparts.com/uploads/Footwell.jpg
