ELUSIVE's Avatar
86 Carrera Brake Caliper Painting ??
Howdy all -
I'm a few months into ownership of my 1986 Carrera and really loving it so far. The weather in Colorado over the past few months has been pretty crappy and just this weekend I was able give her a first bath.
One thing that I have loved about the more modern Porsche's are the red brakes. My 997 Carrera S came with them, however the 2006 Boxster that I recently sold and my 2013 Carrera came were base models so they were not red. In both cases, I was able to paint them with a long involved process of massive cleaning, masking, multiple coats of high temp primer, multiple coats of high temp red, PORSCHE stickers, and multiple coats of clearcoat. The result was awesome.
Here are some pics of before and after on my Boxster and after on my 2013 Carrera:
So my question is this:
What are peoples thoughts on doing something similar to my 86? Clearly the wheels are smaller and less open to see the caliper. I'm very shortly upgrading to 17" wheels so the openings are going to get a bit larger. Is it totally lame to have painted red calipers on a more vintage car like this?
I would appreciate the thoughts of this community!
Thanks!
ELUSIVE
Fan of all things German, especially Porsche, Audi, and VW.
Old 03-02-2020, 11:26 AM
Flojo's Avatar
keep that for the time when a brake fluid change is sceduled. then you can do the following:
- have a new set ready to plug and play swap (job done with bleeding in less than an hour)
or
- take what you have and rebuild (will take you at least a day, if you have a bead blaster)
normally they a plated, golden chromated/zinc plated. but you can paint them. do what ya like.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-02-2020, 11:36 AM
RFP RFP is online now
RFP's Avatar
Oh, please no painted calipers on a '86
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 03-02-2020, 03:07 PM
proporsche's Avatar
this..forget about it;-)))
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-02-2020, 03:46 PM
Antomero's Avatar
Zinc plate the calipers.... Period correct!
Old 03-02-2020, 04:09 PM
Mark Salvetti's Avatar
Besides not being period correct, the big difference between your Boxster and 997 and your Carrera is the sheer size of the newer calipers. I think the puny calipers on the G-bodies look a little silly painted.
Sorry.
Mark
1979 911SC Targa
Old 03-02-2020, 04:21 PM
I just had mine refurbed by PMB; very happy with the classic look...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 03-02-2020, 05:27 PM
rokemester's Avatar
OEM plated, then clear coat to keep them looking pretty a bit longer. I’m just a stock look guy. Do what floats your boat. Black better than red if you want to paint them.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 03-02-2020, 05:40 PM
If every time you look at your 86 you wish the calipers were red than do it. It’s not the end of the world and you won’t lose 10k in value. I like the way your other 2 cars looked.
78 911 st backdate
87 944
00 996
Old 03-02-2020, 05:54 PM
Eng-o-neer
Tremelune's Avatar
"Correct" is an arbitrary fiction. Do what you like.
You might want to look into Boxster brakes. I forget everything, but I recall it being a straightforward conversion without the need of a new master or bias...They'll look the part, for sure, though you probably won't see much behind Fuchs!
Old 03-04-2020, 10:06 PM
The 9 Store
PMB plates them to restore the plating in the piston bore. That's what kept the calipers working for 35+ years. If you just paint, you miss this step.
All used parts sold as is.
Old 03-05-2020, 01:30 PM
