cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Turbo Tie Rod Question
I installed the Turbo Tie Rods on Sat. but have a couple questions as apparently they have changed design.
There is no castle nut and cotter pin on them. Just a locknut that does not work. Before the nut can be tightened down the bolt spins. This make it impossible to get it on an super tight.
I ended up reusing the old castle nut with no cotter pin as there is no hole for one in the new tie rods. I used some locktite blue and will fix install if necessary.
Is there a trick to the trade for the new design or is this a design flaw. I bought them from our host.
Any input is appreciated
Old 03-08-2020, 07:39 AM
It's a 914 ...
stownsen914's Avatar
Maybe try giving some light taps to the rod end with a block of wood and hammer to seat it in the spindle. Might keep it from spinning while you tighten the nut.
Old 03-08-2020, 07:47 AM
Once you get the tie rod locked in place with your castle nut you should be able to remove the castle nut and install the new lock nut. The tie rod should be jammed in place and only removed with a pickle fork. Initially you could have used a "C" clamp to force the tie rod into place and then install the supplied lock nut.
Hope this helps,
Rahl
Drive it like you hate it! 1976 930 Turbo Carrera, Mostly stock...Lightly sweetened
Old 03-08-2020, 07:50 AM
cmcfaul's Avatar
Seems like a design flaw to me but will give it a try. Also, the nut is tiny....why? there must be a reason. That nut has to get torqued down pretty hard.
Thanks,
Chris
Old 03-08-2020, 07:59 AM
A lot of members have expressed their displeasure with these kits the host sells. Lemforder brand I think. Too late for you now, but for what it's worth, you can get these kits through Chuck at Elephant racing with the castellated nuts and cotter pins/holes.
Old 03-08-2020, 10:39 AM
stevie 77 930's Avatar
I just did this yesterday......
Place a jack under the tie rod and jack up so the tie rod is seated tightly. Secure bolt as required torque 33 ft . Release jack , easy !
1983 911SC
1974 914
2018 GTS
2019 Audi S4
'76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 03-08-2020, 05:09 PM
Use an impact wrench. Works like a charm.
Old 03-08-2020, 05:12 PM
cmcfaul's Avatar
Why such a tiny nut? Judging by how much force is required to get the parts separated I assumed it has to be torqued down pretty hard. That tiny nut just does not seem to be up for the job.
Chris
89 Carrera
Old 03-09-2020, 07:02 AM
Pedro '84 Coupe's Avatar
The Lemforder turbo tie rod kit I bought has the castellated nut with cotter pin. I wonder when and why they made the change. Steve 77 930 has the right idea with the jack under the tie rod end.
1984 Slate Blue Metallic Carrera Coupe, 2000 Boxster S, 2003 BMW 530i, and 2016 VW Golf
Old 03-09-2020, 07:44 AM
rokemester's Avatar
Thanks for the tip. Lemforder need to get back to where they were based on this feedback.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 03-09-2020, 05:30 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I cant see the top of the post clearly, but is there a slot or an allen keyhole in the top so you could use a wrench to tighten the nut while holding the post from spinning like struts have?
Marc
Old 03-09-2020, 07:51 PM
cmcfaul's Avatar
there is an indention at the end of the bolt. Not an allen wrench receptacle. I had the same thought. Not sure why it there except to make it easier to use an extractor as apposed to the pickle fork.
Chris
Old 03-10-2020, 09:45 AM
theiceman's Avatar
i'm not sure how a castle nut and cotter pin achieves your objective of reaching correct torque without spinning where the new nut doesnt.
i would think both reach the same torque before the ball joint spins
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 03-10-2020, 11:23 AM
proporsche's Avatar
this is all just about the nut thickness-the tie rod end will go nowhere once is in place so don`t worry much about it......
but did you boys realized that the booth is a crap .I had older stock 930 kit and compare it to the new material on the rubber --you cannot compare it is total crap rubber stuff...i threw it away right away...
Ivan
1985 911 with original 494 972 miles..s..796 580 km
Old 03-10-2020, 11:57 AM
cmcfaul's Avatar
The boots seemed like good quality...pretty thick.
The castle nut screwed all the way on. The lock nut, as soon as the lock part engaged the bolt would spin the bolt. I am going to keep the castle nut no there with a generous amount of Locktite blue. will keep an eye on it.
Did take one turn at speed on the way to the alignment shop....felt good. More of a sports car feel, less of a Cadi feel.
Chris
Old 03-10-2020, 12:09 PM
proporsche's Avatar
If the nut is your concern-really it will not get loose due to the down pressure on it - i suggest to you get the nylock .
Ivan
Old 03-10-2020, 12:48 PM
If you're concerned about the nut coming undone, you might just double nut the thing, with or without the nylock nut.
Old 03-10-2020, 08:20 PM
cmcfaul's Avatar
I think it's fine with the locktite. Initial concern was why the nut that came with the kit did not work. Did not think of the jack solution so went back to the old nuts. Still seems like a design flaw.
Chris
Old 03-11-2020, 06:20 AM
