-   -   Separate alternator from housing? (http://forums.pelicanparts.com/porsche-911-technical-forum/1054515-separate-alternator-housing.html)
Gretz 04-13-2020 09:04 AM
Originally Posted by Trackrash (Post 10778089)
Yes, using a lot of liquid wrench and letting it soak for days mine finally came loose by tapping on the studs with a rawhide mallot with the housing adequately supported. Meaning not on the outside edges.
None of the other methods have worked for me. I guess I'll give it some PB Blaster. Any chance the PB Blaster or Liquid Wrench could cause problems if it gets into the alternator?
HaroldMHedge 04-13-2020 10:26 AM
I don't think PB or Liquid Wrench will cause any problems.
I just used a little heat from MAPP gas and tapped it out this morning on my 87. Go slow with the heat.
Antomero 04-13-2020 11:46 AM
PB Blaster, heat and patience is key!
