-   -   What muffler do I have? 1980SC (http://forums.pelicanparts.com/porsche-911-technical-forum/1054687-what-muffler-do-i-have-1980sc.html)
lada03 03-10-2020 04:44 PM
I decided to upgrade my muffler to a Dansk 2:1 in my 1980SC.
Can somebody tell me what kind of muffler i have now?
Is it stock? The previous owner did a cat bypass and Im curious what muffler he used.
Hoping a 70mm Dansk Sport muffler will fit
Sorry for the bad pictures, i couldnt see any part numbers
http://forums.pelicanparts.com/uploa...1583887222.jpg
http://forums.pelicanparts.com/uploa...1583887247.jpg
http://forums.pelicanparts.com/uploa...1583887435.jpg
Peter M 03-10-2020 10:38 PM
Lada,
You have a one in non stock muffler that looks like someone has fabricated themselves using a generic style muffler as the base.
If you want to use a 2 in muffler you will need to change the headers to a two out style like SSI's or similar.
I'd suggest you just install a 1 in, 1 out M&K muffler and avoid the cost and hassle.
Flojo 03-11-2020 03:05 AM
go for SSI
saves a lot of weight and heat (no cross tube/heat under trans, no pre-muffler/no heat near valve cover).
and the engine breathes more freely (gain of up to to 10hp).
lada03 03-11-2020 03:56 AM
Thank you both for the info!
Decisions ... decisions
Mike Andrew 03-11-2020 04:53 AM
I am running a 1 in/ 1 out M & K on my 80 SC and am very happy. When/if I decide to rebuild and mod for more HP, I will go to SSI's or similar.
Looks like some pretty rusty fasteners holding things together, beyond PB or the like. Should be fun getting the old muffler off unless you have a torch.
lada03 03-11-2020 05:19 AM
M&k
I will go with the Dansk or M&K. Its not too loud is it?
WPOZZZ 03-11-2020 05:37 AM
That may be a Bursch muffler. Through the years they changed silencer brands and shapes.
walt 03-11-2020 11:25 AM
Can't comment on the muffler but if that's Castrol GTX in the background I'd get rid of it. Garbage.
lada03 03-11-2020 12:12 PM
Yes it is, 20w50
Been using it for years
gtc 03-11-2020 12:34 PM
+1
Originally Posted by wpozzz (Post 10779579)
that may be a bursch muffler.
lada03 03-11-2020 12:40 PM
So the consensus its bursch and not stock?
darrin 03-11-2020 03:42 PM
definitely not stock -- here's a link to a representative picture of a stock exhaust system/muffler http://forums.pelicanparts.com/6312451-post1.html
lada03 03-11-2020 05:34 PM
That helps, thanks
lada03 03-20-2020 01:24 PM
better pic
http://forums.pelicanparts.com/uploa...1584739479.jpg
