Crakshaft idenifacation
How can I identify a 2.2 crank vs a 2.4 that is out of the case? Only number on crank is 361891. Thanks Bob Shafer
Sorry, brain fade, should have checked further. The rod bearings are different. Bob
also two vs one hole where flywheel mounts.
john |
Correct, 2 oil hole plugs on the 66mm stroke crank and 1 oil plug on the 70.4mm crank.
Mark Jung Bend, OR MFI Werks.com |
