Spokeworks LED brake light review
Purchased my 1971 911T Targa a few years ago and one of the first changes I always make to my vintage cars and motorcycles is an upgrade to LED lighting for better visibility and reduced power consumption.
I typically use bulbs from SuperBrightLEDs but for the 911 I wanted to support another Pelican member and chose the complete lighting kit from CarMagic which at the time included all interior & exterior lighting minus license plate light bulbs... which I see they do offer now. They also offer LED headlights which I have not tested. All in all I have been very happy with the product but there has been a nagging issue. On at least a handful of occasions people have stopped me to tell me my brake lights were not working. This only occurred at dusk or dawn when the running lights were already on. It seems the difference in brightness between the tail lights and the same bulb with the brake pedal pushed was not signficant enough to register as brake lights for some road users. To avoid a rear end collision or worse I started looking at options. After reviewing many threads on the forum I decided to give the Spokeworks LED brake light boards a try. The Spokeworks LED brake light kit contains the following:
The installation is easy.
Once installed they work just like a regular tail/brake light bulb only much brighter. At this time I am running the CarMagic bulbs for front/rear turn signals and rear side marker lights. I am only running the Spokeworks LED boards for the brake lights. Here are my thoughts on each: CarMagic Pros:
CarMagic Cons:
Spokeworks Pros:
Spokeworks Cons:
If ultimate brightness and clarity are your goal Spokeworks offers these LED Brake boards as well as front & rear turn signal boards, marker lights, fog lights and more. The price may be a bit higher but that old adage about getting what you pay for seems to hold true here. These are engineered specifically for our 911's and made to perform very well behind the OEM lenses. If I were starting fresh today I would most likely go this route. Your safety and the safety of your 911 is worth it. If you are looking for a more authentic OEM look while receiving many of the benefits of LEDs then CarMagic is definitely worth a look. Their prices are good too. Like me you may still want to choose Spokeworks for the tail/brake lights as it seems the best option at this time to ensure other road users can clearly see when you are braking while the tail lights are already on. Photos can not capture the exact brightness and intense red color as seen by the naked eye but they can help illustrate the contrast between the CarMagic and Spokeworks lights as well as the contrast between the Spokeworks tail light and brake light. I hope this review helps anyone thinking about LED lighting. This photo shot from approx 30 ft behind the car ![]() Tail lights shown from an angle approximating being in the line next to the car ![]() Tail lights reflecting against the inside of the garage door ![]() Tail light vs brake light. Tried to use the exposure lock on the iPhone. While the photo does not reflect the reality of brightness or color it does show the contrast between tail light and brake light.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Great comments (& pics)! I installed Spokework lights but haven't used the car yet.
Marv Evans '69 911E |
El Duderino
Nice review. Thanks for sharing.
One suggestion is to also add a high third brake light. Look at the US auto market... sedans are going by the wayside. Everyone seems to be up higher in an SUV these days. I like the idea of getting a brake light more in line of sight of of a SUV driver. The rear lights are just so low by modern standards. I bought the Hella TBL from Daniel Stern several years ago. I’m sure there are other options out there these days... I haven’t really looked at what else is available, but the Hella is BRIGHT.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
I don't disagree and have been thinking of the best way of integrating one into this classic Targa that doesn't look out of place or tacked on.
Brian,
nice write-up and comparison on the LED lights. I'm considering upgrading my cars, especially the '88 since I have a modified bumper without the bumperettes
Rob Cully- Virginia Beach, VA 88 911 Carrera Coupe "88 Ducktail" - Black 2008 Cayenne GTS - Nordic Gold Metallic 74 Porsche 911 Targa - Slate Blue 72 Datsun 240Z (sold) |
Rescuer of old cars
I've had these in both my 911s for a few years. Here are my additional comments to this review.
• I still felt that Jerry's LEDs did not have as much difference between tail and brake as I wanted. The tail lights were too bright. After talking with him about this, I was told that I could dim the tail lights by removing one or two of the surface mounted resistors on the boards. I tried pulling 1 first, and later pulled a second on each board. That dimmed the tail lights significantly. They are still easily as bright as a normal bulb, and the difference between tail and brake is now VERY noticeable. • Lastly, the customer service is great. After 2 years, I found that one board had 3 dead LEDs. I contacted Jerry to ask if anything could be done, and he said he would replace the pair at no charge. When I mentioned that I had modified the boards by removing resistors, in case that might have voided the warranty, he said no problem, and he would build the replacement boards with only one resistor as well. Way over the top service.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 03-15-2020 at 06:10 PM.. |
The 9 Store
I have Spokeworks LED's on the front and back of my 914. The real test isn't at night when you can see most any light, but during the day. The extra brightness gets driver's attention when it counts. Plus, Spoke/Jerry is a great guy to buy from.
All used parts sold as is. |
Coram Deo
![]() The whole discussion is here: Third brake light: Anyone made a housing?. Bit since Spoke didn't take up my challenge, probably he nicest solution is out of a Cayman and looks like this (at least in a coupe- it's not too wide for a Targa):
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Coram Deo
So true. Jerry built a red reverse light board (just for me, as far as I can tell!) as a rear foglight. He takes great care of his customers.
Apologies if this has been asked and answered countless times, but these LED brake lights do not require any chances in wiring or additional relays?
Rescuer of old cars
Turn signal LEDs may require an updated flasher relay, but still no wiring changes.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Coram Deo
The third brake light requires wires run from the brake light wire to the 3rd brake light. Not hard to do it cleanly, especially in a Targa.
I replaced all my rear lights with the Spokeworks boards a couple seasons ago, as well as adding a Hella 3rd brake light in the rear window. They were easy to install and work great— no more almost getting rear-ended. A+.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
I have Spoke's brake light boards in my '88 and the full meal deal in my '87. I can't recommend them enough. The cons are truly nits when compared to the visual footprint improvement they make at night or, especially, day. Think about that when that SUV driving soccer mom is barreling down on you while talking on her cell phone and / or applying makeup. They aren't making anymore air cooled Porsches. They're making plenty of SUVs. The benefits clearly outweigh the costs / cons. This con... Even behind the OEM lens these have the look of tiny LEDs which may not suit the owner who wants to maintain a vintage appearance. ...is also immaterial IMO. Unlike an overt set of LED projector headlights, that an owner sees everytime they walk up to the car, the LED light boards are considerably less noticeable behind their lenses. Again, the benefits of a custom engineered solution easily outweigh the costs when safety (larger visual footprint), reliability (expected service life) and performance (brighter AND less current draw on 30 - 50 year old electrical systems) are considered. The Spoke boards are a win / win / win, no brainier for me.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 03-18-2020 at 05:29 AM.. |
