fuchs clear coated or not
i have an 89 anniv edition silver and was wondering if the originial fuchs would be clearcoated on the lips from factory or not
some tire cleaner i just used seemed to overspray and etch the lip of the wheel...really annoyed but now need to figure out how to remedy it
thx
1989 Porsche 911 Silver Anniversary Edition
1985 Mercedes Benz 500sel Nautical Blue
2012 Mercedes Benz E63 AMG Iridium Silver
Old 03-15-2020, 09:18 PM
Information Junky
island911's Avatar
Clear anodize is the typical finish.
If that got etched... Yikes!
I know some people, when refinishing wheels, use oven cleaner to chemically attack the anodize.
What kind of tire clean was used? It sounds horrible.
Old 03-15-2020, 10:30 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Heat is a factor. Brakes make the wheels pretty hot. Touch your wheels after a spirited run...hot as hell.
Chris
89 Carrera
73 E
Old 03-16-2020, 12:16 PM
factory Fuchs are not clear coated. post a pic of the issue
if the anodizing has been discolored, its likey only a re-anodize will repair it.
Old 03-16-2020, 12:31 PM
https://www.pinnaclewax.com/advanced-tire-cleaner.html
this is the product used
so on my mercedes i have a set of oz aero 3 piece wheels which have bare aluminum on the lips, and i go through the process of hand polishing them yearly with mothers metal polish. you know you get that black residue when it works and u know they are NON clear coated
i tried a little of that on the fuchs and it did not turn black thus wondering about clear coated or not.....but i guess if its anodized then its a whole nother scenario to deal with
i was thinking of using some 2000 grit wet sand and see if that does anything...but check with u all first
Old 03-16-2020, 06:45 PM
Rescuer of old cars
Arne2's Avatar
Sanding won't do a thing. It sounds as if the anodizing has either been damaged or stained. Cleaners for anodized wheels need to be pH neutral, either acidic or alkaline can permanently damage the anodizing.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-16-2020, 08:06 PM
so annoying because it wasnt on there for than 15 seconds just as i was spraying the tire...ill take somepics later
Old 03-16-2020, 09:39 PM
MBAtarga's Avatar
Originally Posted by vdubpower View Post
I see nothing on that page for the product that says anything about being safe for alloy or aluminum wheels. I can't enlarge and read the labeling on the bottle image used on the ad though. If there is no mention, there is probably a reason.
Mark
'83 SC Targa - since 5/5/2001
Old 03-17-2020, 05:01 AM
Bill Douglas's Avatar
Don't sand them. Once you lose the anodizing you will get all sorts of corrosion.
If you don't get a better solution you could put some of the tire cleaner evenly over the rims to get an even color.
It must be nasty stuff. My perfect wheels get peed on by dogs very often. It's their way of saying hello to other dogs in remote destinations. And no staining from the pee.
Old 03-17-2020, 11:35 AM
cpa cpa is online now
vdubpower, without seeing the discoloration your working on it's hard to make a good recommendation. I had very good results on the anodized outer edges that the previous owner had let go until they were quite dull and had a white discoloration. After trying the Mothers foam polishing cone that did not make a difference I purchased some muslin cloth polishing wheels for my drill and used Mothers Power Metal polish. The muslin works like a buffing wheel, work slowly and without too much pressure when you start. You'll get the hang of it after a while. I was able to make them very presentable at little cost, just a little labor. Good luck.
cpa
Old 03-17-2020, 12:53 PM
djpateman's Avatar
Some Fuchs are painted, so yes it is possible that there may be clear coat on the rim.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-18-2020, 05:02 AM
My anniversary car has some water spotting from age etc int eh anodizing. I might try the muslin cloth idea above. I a also planning on having another set of wheels done up to look like the factory ones, so I can save the factory ones. They are getting hard to get now.
Let us know how the muslin works.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-18-2020, 12:20 PM
picture came out upside down but u can see on outer edge
that is where I oversprayed the tire cleaner.
the tire cleaner doesn't comment about wheels because its not for wheels...
Old 03-21-2020, 03:55 PM
Vdubpower. That is on anodizing no clear coat. Mine looked similar. I’m sure you can make that at least acceptable with a round muslin ball and a muslin buffing wheel. Go slow at first you don’t want to burn thru the anodizing.
Old 03-21-2020, 04:05 PM
thanks ... this muslim will give muslin a chance
Old 03-21-2020, 04:27 PM
Don’t forget to post photos when your done for comparison.
Old 03-21-2020, 05:44 PM
