Ignition Switch 1985 911
If anyone has replaced an Ignition Switch in their 911, mine is a 1985, what was the issue you were having? My key turns but only get a single click, power goes on, but the car does not start.
Wanted to know if you had the same problem that a new Ignition Switch fixed.
Old 03-19-2020, 01:19 PM
High Life's Avatar
I would do a search on this forum.. There is discussion on how much of a PITA it is.
Its common.. In fact I need to think about getting a spare switch as mine is doing something similar.. turn it on, nothing, turn it off then again nothing, then again starts up.. Kind a stressful when you are 5 hours from home in rural Minnesota..
Mine is an 1981.
1981 911SC
Old 03-19-2020, 06:41 PM
