Slow old car
The fun never ends: bouncy tach, car dies, alternator ID?
So I took the wife out today to show off how great the car is running now that I’ve spent a fortune on an engine and transmission rebuild.
Great timing. Got the car warmed up, then the tach starts bouncing around intermittently, then dying when I put in the clutch. Takes 20-30 seconds of sitting to restart. Happened on one of the busier roads in town, middle lane, that sucked. I did get it home, wasn’t much fun with it dying every few blocks, but we did it. I let it sit for a couple of hours to cool down, then measured voltages. Everything looked fine at idle, but the engine wasn't as hot anymore. Searching reveals that the earlier symptoms are consistent with a dying regulator, where voltage spikes cause the CDI to go haywire with high voltage spikes, but the dying and inability to start seems like it could be something more, open to thoughts. Anyone familiar with this alternator? The only info I can find on it was a single post on this forum about shops in Australia. Should I just replace this regulator and put it back together? The windings look essentially new, everything feels tight, so my best guess is the regulator has crapped out, based on the bouncy tach. ![]()
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
I assume you don't have a voltmeter installed in the car since you did not mention it. There are cheap voltmeters you can buy that go in the cigarette lighter socket. Real cheap on e-bay, less cheap at your local autoparts store.
Go to have anyway, not just when there is a problem. There are several threads on the topic on Pelican.
Who, What, When, Where, Why and How. |
You likely eliminated this already if you have the alternator out but on my 930 with similar symptoms I found the ground wire from the alternator to the engine case has corroded at the bolt on the case. I had the alternator tested and all OK so went back in and found the bad ground disguised to look like it was fine. When wiggled it broke free.
First let me qualify everything I'm about to post. I'm terrible at electronics. I can figure out the plumbing of wiring, but that's it.
When I had the "bouncy tach" problem, it ended up being diodes in the built in regulator. My tach was more than bouncy; it would also run backwards (jump to ~6000 and then go down as the rpms went up). I managed to limp the two miles home. Anyway, that's what I was told by the shop I found. I had to find one that knew about the older electronics. Was directed to it buy an older, established air-cooled Porsche shop. I do think it resulted in damaging the tach itself. Afterwards, one of the dampeners in the tach was fubar and it would bounce when I came off the accelerator. Sent that in to a speedo shop to fix. |
Slow old car
I haven't been able to find anyone in town who can test this alternator. The only shops in the Portland area that have testing equipment are the FLAPS folks, and their equipment is not compatible with this kind of alternator. The regulator was only $30 for this alternator, based on the bosch part number, so I've ordered one and hopefully I'll be able to test both soon.
If you're looking for a reputable alternator repair place and don't mind shipping or driving north to the Seattle area, Romaine Electric is where I had mine repaired a few years back.
I had a bouncy tach, and replacing the VR along with making sure the grounds are clean made the difference. I used a unit made by Valeo (OEM but made in China if you can believe it). Although, it did take about a month to get because it was dropped ship straight from Germany by way of Florida. Didn't want to chance a unit made by HuCo
Paul 1987 Carrera coupe Last edited by Ok here we go; 03-16-2020 at 01:06 PM.. |
There absolutely has to be a shop in Portland that can test your alternator. I’m sure someone will chime in with a name shortly.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Slow old car
I hope so! I spent quite a bit of time between the google machine and the telephone and couldn’t find a single business that is both 1)still in existence and 2) capable of spinning an alternator without a pulley on it.
When this is happening and you put your voltmeter on a 12V wire (maybe the cigarette lighter) did the reading jump around?
Find Spoke's LED Products: www.spokeworksled.com |
Slow old car
Based on my research it looked fairly conclusive that it was the voltage regulator. Now I know that it could just as well be the green wire I guess. My green wire is the one-piece type, as opposed to the kind with the connector that our host sells. If my problem persists or returns once I get the new VR installed, I'll next go to the green wire. bleh. I hate throwing parts at a problem.
There's 15V capacitors in both the tach and the speedo, IIRC. They don't much appreciate being fed more voltage than that on a continuous basis. Like when the regulator goes screwy.
They also just get old and eventually die; probably more likely to do that if they see voltages higher than they're rated for. Replacing with 35V caps isn't a bad idea.
'77 S with '78 930 power and a few other things. |
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
The test for this is very simple. Pull the connector off of the spark unit and find the 2 wires going to the distributor. Put your ohm meter across these wires and measure resistance. It should be in the 40-80 ohm I think. I would read 50 ohm then zero when I jiggled the wire near the distributor. You'll need to clip the wires on the connector so you can measure resistance as you jiggle the wire. An assistant also helps so they can hold the DMM leads on the connector while you mess with the wires.
Slow old car
That’s excellent- thanks!
