Front Fuel lines install question
I got the 2 lines through the tunnel. Grommets are split so installing them shouldn't be too bad (we'll see). I cut the old lines to remove them from the metal "bale" above the steering rack. The question is: do the new lines need to go back through the metal bale? Not sure how to do it. And if I do need to, is the order critical? Left to right?
Car is a 78 sc Thanks in advance |
Test
Got it
No part of this job is fun. But I do feel good that they are where they are supposed to be. Now on with the other grommets and hooking up the front lines.
Sounds like you are all set. I assume you have already reviewed this thread?
http://forums.pelicanparts.com/porsche-911-technical-forum/792001-okay-so-i-am-going-replace-my-main-tunnel-fuel-lines-tomorrow-any-suggestions.html Mark |
Fuel lines
I did many searches but did not find this one. How is that possible? Anyway, the one thing that scares me a bit is the longer screw. I did not pull the center section where the shifter is. I guess I will reassemble and check for leaks visually and with my nose.
| All times are GMT -8. The time now is 12:31 AM. |
