Potential Oil Leak From Lower Valve Cover on a 930
Hi
Just wanting to check my thinking before I send the car for a repair or do it myself.
I have a couple of oil leaks on my 1985 930 (44000km), the time chain is leaking but this isn't my biggest issue.
Ive checked the top of the engine which is dry but I think I also have a leak from the passenger side lower valve cover, is the possible on a 930.
I've tried to add some pictures to help (sorry I was laid on a floor in a carpark space at my apartment).
Any suggestions welcome.
My timing chain cover leaks on both sides and the value cover on the other side is clean. Plus with the positioning of the chain cover and the valve cover I would have though oil would not blow from the chain cover onto the valve cover.
I the first picture with the black hose/pipe, the top part of the hose is dry, seems to get spray on it.
www.outlawgarage.com.au
Old 03-16-2020, 10:56 AM
proporsche's Avatar
it could be this oil leak ..upper camshaft oil line bolt is loose or even the fitting the the camshaft housing is leaking ..on thsi picture
Also..it could be you camshaft cover o ring and gasket...can you make a picture so we can see behind the air hose towards the chain housing where it meets the camshaft housing??
the one with the black arrow..is my 1st guess..
1985 911 with original 502 191 miles...808 198 km
Old 03-16-2020, 11:45 AM
I'll take a picture shortly
I assume they can be fixed with the engine coming out?
Old 03-16-2020, 05:22 PM
Be very careful with those oil leak A friend just lost a beautiful 87 930 to fire from an oil leak
Everyone is very careful with gas lines oil burns too!
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 03-16-2020, 06:17 PM
spoke's Avatar
I have an '86 930 with a leak that would be exactly where you have the black arrow. I can see where the hose is attached to the fitting and the hose, pipe and pipe end are completely dry. Not sure about the base of the fitting where it goes into the head though. I'll have to look more closely at that point. It's dripping a lot of oil right now so I need to get on this.
Find Spoke's LED Products:
www.spokeworksled.com
Old 03-17-2020, 09:49 AM
proporsche's Avatar
what happens is when someone replaces the camshaft oil line the fitting gets a little loose and after time it leaks.Remove the trough bolt and either remove the fitting and replace the alu washer or just make it tight..if it loose replace the washer i`d say...
Also it could be from your camshaft cover O ring or the gasket..but try this 1st...
Ivan
Old 03-17-2020, 10:45 AM
Power wash/degrease the affected areas, then allow to dry. Drive car, then inspect for source.
Sherwood
Old 03-18-2020, 08:33 PM
spoke's Avatar
Ivan
Can the aluminum washer be sourced locally like from a FLAPS? I don't see too many alu washers on PP.
Old 03-19-2020, 02:30 AM
proporsche's Avatar
spoke ..sorry i do not know the source all i have is original alu washers from gasket sets..
here is the part number 91110891100...it seams it is available in copper..if you cannot find it i can send you some i have plenty alu. type.....just have to pay for shipping...
Ivan
Old 03-19-2020, 03:38 AM
spoke's Avatar
91110891100 is $4.75 for stupid brass washer. I may take you up on the offer of an alu washer. I'll dig into it this weekend and clean everything like 911pcars recommended.
Old 03-19-2020, 03:49 AM
proporsche's Avatar
sorry about that...let me know in Pm your address..if you decide
Ivan
can you take a picture from the front -right behind the valve cover for me? to see it?before you clean it?
Old 03-19-2020, 05:32 AM
So, have you determined the source of the leak or just going to start replacing parts? There are potential leak sources not yet identified.
Old 03-22-2020, 03:51 PM
