vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Mechanical Hood Struts
Anybody try the mechanical hood struts? I have been through my third set of pneumatic struts and I am going to give them a try. Will I need two of them or could I get away with just one?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-01-2020, 08:12 PM
Driver
Noah930's Avatar
You're referring to the $75 Rennline ones? While it's not hard to replace the hood/decklid struts, I do it just infrequently enough that it's always a minor PITA. I'd be interested in the consensus, as well.
1990 Black 964 C2 Targa
Old 05-01-2020, 08:27 PM
Rennline works very well. Installed on two cars. Nothing but positive
Old 05-01-2020, 08:29 PM
7783911's Avatar
Rennnline work well, i installed 2 on front but in the end, took one off and put regular on so i have a bit of a lift and a lock model. The rear deck strut from rennline is great
Old 05-02-2020, 03:40 AM
vesnyder's Avatar
Yes, I am looking at the $75 Rennline ones. Last time I installed mine it was a major PIA! If I remember correctly, I never did get the one clip on. Not looking forward to it. Last ones I purchased I got the "lifetime guarantee", but if they are going to fail every 4-5 years it is worth it to me to try something else.
Vance
Old 05-02-2020, 04:31 AM
I installed the Rennline struts on the '70 front and rear. They work great and very nice quality.
And yes the left front is a bit of a pita but no more so than many other things on a 911. Worth it.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-02-2020, 05:13 AM
Upier's Avatar
I got a pair from Rennline for the front of my 86. They are great. Wish I had done it sooner. If you do buy them make sure you get a pair and let other know you have them so they don't try to force it closed.
'86 Targa (Mighty Mouse)
'11 997.2 Carrera S Coupe (To be named)
08 M3 - Sold
"Having a sports car that you only take to car shows is like having a race horse you only take to the petting zoo"
Old 05-02-2020, 07:15 AM
I have been using one for over 10 years now, this one was not available for years. The last hood strut you will ever buy and it is not affected by the cold weather.
The rear one is a very good addition for the heavy tails.
Mechanical Hood Strut?
Old 05-02-2020, 08:14 AM
Vance,
I only use the right one on my hood.
Old 05-02-2020, 08:17 AM
I use them, and I generally like them, but it also makes the hood like the 356 which can cause damage if someone doesn't know it's mechanical and pushes down. I've caught myself a few times trying to push.
They also don't open as much as gas struts because they need room to be lifted to engage / disengage.
Old 05-02-2020, 08:56 AM
I'm good with tools.
AG81's Avatar
just installed a set...... very happy.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 05-02-2020, 09:12 AM
They work great. There is potential to bend the lid by someone unfamiliar with how they operate or don't realize they are installed. Ask any 356 owner.
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 05-02-2020, 11:07 AM
sugarwood's Avatar
There is one caveat to these. If a shop doesn't remember you have them installed, the lid will appear to be stuck. If they try to slam it closed, the hinge will bend.
1986 Bosch Icon Wipers coupe.
Old 05-02-2020, 11:28 AM
walt's Avatar
I have these on my fiberglass deck lid. They eliminate the distortion from a gas shock when the lid is closed, the seams stay flush.
Walt
82SC 3.0
81SC 3.6
Old 05-02-2020, 11:39 AM
I just installed 2 of them today on my ‘71 Targa. I really like them. A high quality item. The passenger side installs in 10 minutes. The driver side installs after a significant amount of cursing and one skinned, bleeding hand. YMMV
Old 05-23-2020, 03:13 PM
Maybe I'm just a lot cheaper than you guys. Or maybe we had this trick four decades ago and it got lost or forgotten somewhere along the line.
Cut off a 3.25" piece of 3/4" pvc pipe, then remove one end of the engine cover strut and slide the pvc pipe onto the strut. When you open the engine cover, slide the pvc pipe down onto the shaft and it falls into place, holding the hood up. When you want to lower it, lift the pvc pipe up and pull it back to the strut main body. Easy peasy. Paint it black if you're worried about appearance.
Old 05-24-2020, 07:12 AM
MichaelSJackson's Avatar
dannobee,
I assume you only use this on one side? Any torque issues while sitting open?
Old 05-24-2020, 08:14 AM
Engine covers only have the strut on the LH side.
Old 05-24-2020, 11:43 AM
dannobee,
My engine cover has a metal whale tail. Last time I replaced the strut, I added one on the RH side.
But I was asking about your front hood. You don't use this idea up there?
I think I'd paint it orange to get the attention of anybody else trying to close the lids.
Old 05-25-2020, 09:05 AM
