2.8 parts for my B-day came today
2.8 Parts and gasket kit came today for my early B-day present to myself. 92mm cylinders and J&E 9:5.1 Pistons from EBS Racing in Nevada. Thanks Troy! MOD S cams. Cant wait to get started tomorrow putting motor back together.
Did you have your cylinders bored and plated, or are they new?
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
They were bored and plated
That ought to rip! Look forward to seeing your progress.
That's the plan. I'm just try to decide on induction. 46mm PMOs or a good deal on a EFI system.
If you go with carbs, don’t go too large. Were at 2.7, same cams as you, but short stroke. Were running weber 40s with 34mm chokes. More than enough.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet |
After talking with Paul Abbott I'm going to try my 40s with 36mm venturis. See how that works out.
Will be awesome! Great engine build. Revs like mad with that combo
No physical quantity completely explains its own existence |
It should rev nicely. I'm also running a Sachs aluminum light weight 10lb. Pressure plate and Fidanza 5.5lb aluminum flywheel.
Listen to Abbott on the carbs. He knows his stuff. Mine revs very quickly because of the 66mm short stroke crank. Don’t go to light on your flywheel/clutch assy. You need some rotational mass or you will stall on takeoff. My car only weighs 1800 lbs, and I have a tall 1st gear. I kept the flywheel stock, but run a Kennedy aluminum pressure plate, stage 1. I can roll away without even giving it gas, even in 3rd gear, by mistake sometimes.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet Last edited by rgofast; 03-26-2020 at 12:55 PM.. |
I'm also running lower gear ratio. 7:31 R&P. As a 2.7 spec. With 964 cams it pulled good from a stop. Same aluminum pressure plate and flywheel. Car weighs 2, 300 now. When I install 2.8 I will be lighting it up with fiberglass bumpers, hood,front fenders and Ducktail. Hopefully get it down to 2,000. Oh I'm trying to loose some weight also. Hopefully 30lbs.
Are you going to modify the transmission?
I already had that done. Was rebuilt recently with,7:31 R&P, Taller 5th gear, Wevo retaining plate.
