-   -   Dual-stage switch knob illumination (http://forums.pelicanparts.com/porsche-911-technical-forum/1055624-dual-stage-switch-knob-illumination.html)
Attylla 03-22-2020 06:25 AM
Hi Pelicans,
I need Your help.
I got stuck trying to figure out the illumination of dual-stage switch.
I believe this type of switch is used for dual-stage rear window heating as well as front + rear fog lights
Does this type of switch have any illumination when operational?
If so how/where to find it?
It has a green semi-transparent top cover
http://forums.pelicanparts.com/uploa...1584883254.jpg
There seems to be no (place for)bulb socket not glow stick on the bottom
http://forums.pelicanparts.com/uploa...1584883343.jpg
Finally the knob seems to be fixed to the control arm
http://forums.pelicanparts.com/uploa...1584883406.jpg
Can anyone help?
Am I right hoping this switch can be used to connect front + rear fog lights
Marcin
Duc Hunter 03-22-2020 06:40 AM
It does illuminate. I found the wiring on here somewhere. Mine are installed and I might be able to take pictures later. When all the way in there is no illumination. When pulled out to step 1 or steps 2 the Illuminati is the same, on.
AG81 03-22-2020 07:00 AM
Yes it does light up. Gently pry the the green disc out of the rubber and check the bulb. Might just need a bulb.....
Attylla 03-22-2020 07:45 AM
Thank You both @Duc Hunter and @AG81
I will try to dig into it from the top.
rw7810 03-23-2020 07:15 PM
That is a switch for a 74 to 89 , rear defrost. I have one for a 69-71 of you need a picture or need to buy the real deal.
