Attylla's Avatar
Dual-stage switch knob illumination
Hi Pelicans,
I need Your help.
I got stuck trying to figure out the illumination of dual-stage switch.
I believe this type of switch is used for dual-stage rear window heating as well as front + rear fog lights
Does this type of switch have any illumination when operational?
If so how/where to find it?
It has a green semi-transparent top cover
There seems to be no (place for)bulb socket not glow stick on the bottom
Finally the knob seems to be fixed to the control arm
Can anyone help?
Am I right hoping this switch can be used to connect front + rear fog lights
Marcin
'70 911T
'75 911S
'81 928S
Old 03-22-2020, 06:25 AM
It does illuminate. I found the wiring on here somewhere. Mine are installed and I might be able to take pictures later. When all the way in there is no illumination. When pulled out to step 1 or steps 2 the Illuminati is the same, on.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-22-2020, 06:40 AM
I'm good with tools.
AG81's Avatar
Yes it does light up. Gently pry the the green disc out of the rubber and check the bulb. Might just need a bulb.....
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 03-22-2020, 07:00 AM
Attylla's Avatar
Thank You both @Duc Hunter and @AG81
I will try to dig into it from the top.
'70 911T
'75 911S
'81 928S
Old 03-22-2020, 07:45 AM
rw7810's Avatar
That is a switch for a 74 to 89 , rear defrost. I have one for a 69-71 of you need a picture or need to buy the real deal.
Robert Williams
70' 911T
Old 03-23-2020, 07:15 PM
