you see Arthur...
jasonlee's Avatar
idle drop
its been a while since I posted. I hope you are healthy and safe during this time.
Quick question, 82 SC, starts like a champ pulls great, but have issues with he idle drop after started. Sometimes it drops to around 950, but more recently it is not dropping, and if it does it only seems to drop to about 1200-1500 rpm. Not sure what the issue is, but would appreciate some insight. I have some time now to tinker with it.
thanks
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 03-25-2020, 06:34 AM
Administrator
Dmitry at Pelican Parts's Avatar
Check out this tech article, it may help you out a bit with the idle speed.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/23-Timing/23-Timing.htm
Old 03-25-2020, 10:38 AM
