Sunroof and headlights wiring problem
Hi Everyone,love this site.I have a 1977 911 that i got taking apart.
Trying to get sunroof to work,put a new switch and checked power at fuse is good.
Any ideas?
Also none of the front lights work.I noticed when hooking the headlights up the was a brown wire that did not go into headlight plug.I thought it was ground and grounded to headlight bucket.
Any thoughts on this also
Thanks so much for any help
Old 03-31-2020, 09:39 PM
On the sunroof I can not find a flow diagram, on the headlight switch.
E1 = light switch (on the top of the drawing)
E4/5 = high-beam stalk
L1/L2 = headlights
K1/K2 = high beams
And yes, the brown wire should be connected to your sealed beams and provides the ground for the bulbs inside !
Old 03-31-2020, 11:53 PM
Sorry img didn't load in prev reply
Send me a pm and I can send you the PDF with the electrical schema
Oh and here is the diagram for the sliding roof for a model '75 : (unfortunately without wire colours)
83 SC Sunroof Wiring Diagram
Old 03-31-2020, 11:55 PM
