Burgsailor
What is this - 82 sc
Replacing the fuel filter I noted pictured piece was broken. Mounts just below the filter. Have no earthly what it is/does/functions. Appreciate any help. Thank you.
Old 03-29-2020, 11:35 AM
El Duderino
tirwin's Avatar
No picture.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-29-2020, 11:38 AM
Can you try again with the picture please
walt's Avatar
Ox sensor connector? They tend to get brittle and break with age. Are you running a sensor?
Walt
82SC 3.0
81SC 3.6
Old 03-29-2020, 11:45 AM
Burgsailor
Strictly stock. No aftermarket pieces. It’s an ox sensor? Haven’t chased the wires to see if they feed to any exhaust ports but a quick look doesn’t have me thinking it’s going to the exhaust.
Old 03-29-2020, 11:49 AM
Burgsailor
Done. Sorry Ian. First post and fumbled
Old 03-29-2020, 11:50 AM
El Duderino
tirwin's Avatar
If you’re talking about the broken orange connector that is indeed the OXS sensor connector. There is a guy here with the handle Louie_85 (maybe no underscore?). He makes replacement connectors as they are no longer available.
You can send him a Private Message (PM)
Old 03-29-2020, 11:58 AM
El Duderino
tirwin's Avatar
Forgot to add... totally common failures. Those things disintegrate with age.
Old 03-29-2020, 11:59 AM
Flat Six
Flat Six's Avatar
O2 sensor plug
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 03-29-2020, 12:07 PM
If the connection is good, the broken plastic part doesn't matter.
206 637 4071
Old 03-29-2020, 12:21 PM
AndrewCologne's Avatar
Or simply add a new connector the the wire like a "superseal" one.
Which is btw much more comfortble for pullin and pluggin than the original.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 03-29-2020, 12:58 PM
Burgsailor
You guys rock. Appreciate the assessment and gouge. Copy all.
Btw - a chuckle for the wrench turners: “honey - I’m just going to go swap a fuel filter - 30 minutes I’ll be back.”
5 hours later the scene.
Old 03-29-2020, 02:18 PM
