915 Rebuild - Reassembly & Gear Offset
I'm doing a rebuild of the 915 in my '85 Carrera project - new synchros/dog rings/sliders as well as a 1 piece retainer plate. So far everything has gone well and I've just test dropped in the gear cluster into the transmission case. I've noticed that gear sets 1, 2, and 3 show a small amount of axial misalignment - with the worst offender bearing 1st gear. Is this typical?
What's interesting is that 4th gear seems well aligned, and the 2nd and 3rd sets are offset in the opposite direction of 1st. See pics below:
Any feedback would be appreciated!
- Ian
Old 03-26-2020, 09:40 AM
kevingross's Avatar
Hmm, not really sure. Did you get any of the spacers mixed up / interchanged?
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 03-26-2020, 01:48 PM
Mine was the same. Hard to see, but it's the same.
Old 03-26-2020, 02:00 PM
Under the radar
Trackrash's Avatar
There needs to be some offset so the gear teeth don't hit the dog teeth.
If you look closely at the small first gear it looks like the wear pattern is the same as the current placement of the teeth.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-26-2020, 02:38 PM
A comparison pic - just what I was looking for! Thank you.
I, too, noticed the contact pattern matches up with the current stack. Everything spins smoothly - so I can only imagine that this correct.
Old 03-26-2020, 02:56 PM
Sboxin's Avatar
Rebuild photo - additional data point . . . work done by California Motorsports Lake Havasu City, AZ . . .
Regards,
Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 03-26-2020, 03:53 PM
gearhead
Not a problem.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-26-2020, 04:23 PM
