Shock absorbers with spherical bearing/ball joint
I am looking for shock absorbers that have on one end a spherical bearing/ ball joint and a stud on the other side.
Do you know a company that sells such shock absorbers ? Spherical bearing something like this one
Navin Johnson
Yes, I used Koni 3012's on the rear of my 911..
https://www.truechoicekoniracingservices.com/wp-content/uploads/2019/01/2017_TKRS_Catalog.pdf If you change the upper mount a world of options opens up regards to shock choices.. Clevis adapters: http://www.tarett.com/items/914-products/914-suspension/914-shocks~springs/shock-clevis-adapter-pr-rsrsca-detail.htm https://parts.turbokraft.com/products/shock-clevis-mount-set-rear-upper
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 03-25-2020 at 06:01 AM.. |
Navin Johnson
Sorry, really didn't answer your question.. Not sure who make a monoball lower mount with stud upper mount
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
TimT,
thanks for your answer. It seems Koni can do that upgrade. In the catalog there is an eye spherical bearing upgrade. I will give them a call. |
The rear Bilstein RSR shocks at Rebel Racing appear to have that feature
https://www.rsrproducts.com/product-page/bilstein-rear-rsr-shock Last edited by Harpo; 03-25-2020 at 05:47 AM.. |
Rebel Racing Products offers steel-bodied rear Bilsteins, threaded upper stem, spherical bearing lower mounts and custom-valved per customer specs (spring type, spring rate, ride height, vehicle weight, tire compound, operating conditions, etc.).
![]() They can be sourced here: https://www.rsrproducts.com/product-page/rsr-products-bilstein-custom-steel-body-shocks RSR Products / Bilstein Custom Steel Body Shocks – John James Racing Here's a comparison between the above product and a Bilstein RSR racing shock (shock body length varies according to application and ride height: ![]() Bilstein also supplies the needed components to use coil-over springs. Sherwood (no affiliation) updated, 4-15-20 Last edited by 911pcars; 04-15-2020 at 06:06 PM.. |
Thanks for your answers.
