3.2 ICV connection test
I suspect something is wrong with ICV. I tested the actual part and it’s functional. How can troubleshoot the electrical connection?http://forums.pelicanparts.com/uploa...1585357418.jpg
http://forums.pelicanparts.com/uploa...1585357481.jpg |
I ordered a new Bosch plug with new contacts and mine works better than ever
84 carrera Sent from my Pixel 3a using Tapatalk |
If you do not have a scope, the best way would be to check for consistent continuity between the ECU connector pins that control the ICV and the pins on the connector shown ?
If you have a scope, look at the signal the ecu puts out to the icv ( with the icv plugged in ) by backprobing. It should look like block waves. In any case clean the contacts of the connector and icv wth some alcohol. |
| All times are GMT -8. The time now is 10:36 AM. |
