Diving in 911
964 Heat exchanger differences..
I am putting a manual motor in my tip 96 and the heat exchangers are different, at least the drivers side is. The TIP exchanger has an additional heat shield under the trans. I am thinking I would heat tape the crossover pipe to replace that shield. Anyone know of any other difference it would make, or if this would be a suitable workaround? Mild climate, likely not more than a 1K miles a year will be going on it.
Thanks Pelicans! Hope those of you staycationing are getting ***** done! ...and those of you on the front are staying as safe as can be. You are appreciated!
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 03-28-2020, 02:08 PM
Diving in 911
Nobody huh? That might be a first for me. Lol
Old 03-29-2020, 12:28 PM
