LinkBack | Thread Tools | Rate Thread |
Analog Air Cooled
Am I ok to use a wire wheel on my muffler and some oxidized aluminium?
Just wondering if I screwed up anything... I decided to tidy up my engine bay and underside of my car. I have a few wire brush drill attachments and had some whites Aluminium Oxidation that wasn’t coming off with cleaners, fan frame, bolt tops, pipes..
I like a non dirty rusty muffler. I do know that some oily dirt under the fenders acts as a barrier. Still, my car had no rust on it but I’m always looking. Also, there was a bumper support that must have taken a hit before me, and had a little rust. I used the wire wheel to get the rust off and used some rust inhibiter and will paint the outside till. So here’s some pics. Wondering on finishing the muffler.. Won’t touch the block. ![]() ![]() ![]() ![]()
86 Targa 91 964 13 6 SPD Cayenne |
No real opinion on what you're doing.... just make sure you use eye protection. Wire fragment in the eye is no joke.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Analog Air Cooled
100%. Normally I have a mask on too but the wind was blowing it all away. I just don’t know if I’m ruining the surface or should apply something to it once it’s clean.
I would paint any of the simple brackets, like the one that adds support to the fender.
I would not paint the muffler or anything else that gets hot. |
Analog Air Cooled
Of course. But just shining up the muffler won’t hurt it right?
Some thoughts, use a brass wheel rather than steel. If you clean fittings, they will just corrode even faster as you have removed any left over plating and exposed bare metal. I cleaned up that bracket that protects the wiring for the fuel level sensor and it looks worse now. That first picture needs a weld repair. Lots of corrosion, was or is your car near salt water?
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Analog Air Cooled
If I can get a new one I will if not, welding it is. Agreed with brass and it was wondering about that plating. My try a thin coat of rust proofing oil. I wonder about the muffler..
It's a 914 ...
If your car is an 86, I think the stock muffler is a 4xx stainless alloy, which will rust some (just not nearly as bad as steel). I don't recall that they are coated since they are stainless. In which case I wouldn't see any harm in taking a wire wheel to it.
Analog Air Cooled
Awesome! I took a soft brass dremel brush to the gold plated hardware. Once the oxidation was off I used a wipe of rust inhibiter on them. A little Mguires Ultimate Black on the intake and plastic/Rubber. Also the plug Gaurds. ![]()
Wire brushes using steel wire can break off and embed into softer materials. If so, the wire will corrode (rust) and will appear in the softer material.
A more thorough method of cleaning, especially for subsequent coating for paint, is to use one of several "blasting" processes (sand, glass bead, walnut shell, vapor, etc.) or chemical dipping. A conversion chemical like POR can be used, but it's not heat resistant; better for non-heated parts. Sherwood |
Analog Air Cooled
Good to know. Man o man I love this forum and you guys.. Knowledge bank is huge.
Fleabit peanut monkey
Genuine Porsche support bracket - $23.
https://www.pelicanparts.com/More_Info/91150162801OEM.htm?pn=911-501-628-01-OEM&bt=Y&fs=0&SVSVSI=807
1981 911SC Targa |
Hotshot,
It looks like that oil line in picture #3 above needs to be replaced ASAP! You don't want to have that come apart. Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
Analog Air Cooled
I noticed that. It had surface corrosion on it and I used the wheel and found that. It has a little crack in just on the base. Agree it needs replacement but there’s been no leaks and the PO had the car 7 years. Defiantly monitoring now as I literately just found it.
Earthling
I’d be careful wire brushing aluminum and rust (iron oxide). Mix those two and you get an exciting compound known as “thermite”.
1996 Porsche 993 C4. His 1979 Porsche 911SC - sold... and now BACK again! Hers 2021 Volvo V60 (foul weather drive) 2024 Volvo XC60 (spousemobile) |
Analog Air Cooled
Go on...
Earthling
Analog Air Cooled
Wow. For years I’ve used a wire wheel to polish metal and remove rust off of things. Glad I hosed everything down after.
So... what do you use?
Earthling
Well, you’re probably ok to use a wire brush because it likely won’t generate enough heat to ignite the mix. I’d avoid using a grinder though, unless you clean the dust covers before / after aluminium grinding / shaping.
Analog Air Cooled
It was a wire brush on a dremel and a drill.
