It’s probably keeping the motor from working much harder than it needs to, and a premature failure.
I originally put the regulator back in and tan it with the helper spring broken and it was terrible but I thought thats just how it ran. Now that I fixed the helper spring it runs really well.
Reiver
I had a very slow passenger side for years and knew what the issue was but had to bring myself to mess with it...as you did. Works like new now and should have done it years ago.
De Oppresso Liber Strength and Honor 5th Legion |
Yeah, except my only issue now is the passenger window switches do not work. The drivers side works fine so I checked all three switches on the drivers side and they work fine so the switch is not the issue. When I plug them all in and press down on the passenger side window switch (either from the drivers door or the passenger door) nothing happens. If I take a jumper box and jump the wires to the passenger window it rolls up and down.
Is there something Im missing somewhere? |
check that your passenger window switches are wired correctly (especially the wires sending power / ground to the passenger window switch from the harness). Believe another post (on another thread?) showed how these are supposed to be wired up. Since each wire plugs into the swicth separately, they can/do get mixed up.
I followed that schematic (I know the one your referring to) to ensure they were plugged in correctly and I still get nothing.
1. I know the motor works, I rebuilt it, bench tested it and also jumped the wires to the motor once installed int he car and the window goes up and down. 2. I know the switches work because I connected each of the three up to the drivers window and they all raise and lower the window. 3. I believe I have all the wires plugged in correctly. I double checked the schematics and double checked the wires but that could always be a possibility. |
I'd go with #3 -- specifically look for continuity between the connections on the driver's side passenger window switch and its counterpart on the passenger's side -- with all the mods your car's been put through, possible that they are no longer attached (which would cause everything to look good on the driver's side where the power/ground are coming IN, but be dead in the passenger door itself)
Thats actually a good idea. I never checked to ensure I had power to the passenger door switch
follow the electrons
I check power on the driver side passenger switch and I have power there. I do not have power on the passenger side of the car.
Where donI go now? Is there a fuse or relay between these points? |
Do not believe so, believe they're simply connected by a wire -- you could either try to find/trace the existing wire from the driver's door through to the passenger's door or simply pull a new wire to replace -- something as basic as 18 gauge speaker wire or a reporposed extension cord wire should work just fine for this
Where would I pull it from? It ends at the switch but where does the other end start? Is it from the other drivers side-passenger switch?
I'd start by checking continuity of these two wires. If you find continuity from door switch to door switch (i.e. the wires aren't cut), then check the ground. If not continuity, you could temporarily run a wire to replicate the red with white dot or red with black dot wires to confirm that replacing these wires will make your passenger door window work. If/when you confirm these wires are indeed broken/shot, you'll need to fish new wires from your driver's door and into your passenger door -- put some dishwashing soap on the wire before fishing through to make things easier. Make sense? |
Got it, Ill let you know how it works out
When I look at the schematics for the drivers side passenger window, it should only on red wire that is doubled up but on my car I show two red wires that are doubled up. Any ideas why? Is this normal?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Wirring.
What does the CKT I sent you show?
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
According to the schematic you sent me, this looks normal then.
So Im not getting power or ground at the passenger side switch on the passenger door. I tried to trace the wires but they look like they run in a bundle under the dash and I cant track where they go to.
Then I ran a 12v wire from the drivers-passenger window switch to the passenger switch and ran a chassis ground to the brown wire and the passenger switch was able to raise and lower the window but nothing worked on the drivers side-passenger switch. Did I do something wrong? |
It looks like you are doing well with a fault tree analysis. It is at this point that I am going to say that your connection from the passenger door to the A-pillar is not right. Perhaps you can take a look at this connector and see if it is making a proper connection(??)
![]() Also: because I am in the passenger side door right now: I see your wiring selection a bit odd: Where are the green and black wires (that go to your motor)? (I am assuming that you’ve omitted them from the pic...) And because I have been fighting with wiring a bit, I found that once you’ve been able to determine which wires go where here, it is best to mark them (I like craps, what can I say...) ![]() At least for *me* .... I am better at numbers than I am remembering colors; so I’ve adopted this for the future. (May be helpful; but everyone’s different).
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
