What is this connector?
I have one on each side of the front trunk but they are disconnected. I tend to think they may be the wires to my power mirrors since the mirrors are disconnected but Im not sure.
Power mirrors
yep mirrors
Ok, so I assume I am missing part of the harness then. Where do those two plugs connect to?
Kroon Wire Harnesses
mirrors
These plugs connect to the following looms:
driver side: 911 612 165 01 https://www.kroonwireharnesses.com/index.php?route=product/search&search=911%20612%20165%2001 and: passenger side 911 612 166 01 https://www.kroonwireharnesses.com/wire-harness-passenger-s-side?search=911%20612%20166%2001
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
So is that wire, which looks like a male plug connector running to my mirrors or somewhere else? I tried to follow it on the drivers side and it looks like it joins into a bigger wire harness that is behind my dash and then continues on to the passenger side of the car.
mirrors
Yes, the harness you have will look like this one. part.no 911 612 164 03
https://www.kroonwireharnesses.com/wire-harness-lhd?search=911%20612%20164%2003 It runs from left to right and is supplied from the front fusebox.
So if I have that wire and I have the wire hanging from the mirrors inside the door then what parts am I missing?
I am missing the mirror switch over button under the dash and I have gotten in behind the gauges but cant seem to even find the connector to add the button. If I have the wire int he picture then it looks like it should have that part of the cable but I cant find it. |
If you follow the brown wires from the supply harness connected to the ground loop from the dashboard, you should be able to find the wires for the left/right selector switch. Three wire's, blue, green and black-yellow. Another wire (grey-green) is connected to your rear window heater switch.
Thanks and Ill take a look. My car is cabriolet so there is no rear window heater
There a rubber grommet with plug on each side up near firewall inside fender.
