87 - Help with removing and replacing engine mounts
Original Post:
Got two new engine mounts. Figured...this can't be that hard. Well..haven't gotten a single bolt off. How the heck did you guys remove the two M8 bolts while holding the nut on the bottom? I even have a 13mm offset wrench..but I can't seem to get that thing on the nut. I gave up. Back to quarantine. :D SUMMARY EDIT: I figured I update everyone on how things turned out in case someone ever searches for this information. As it turns out my 1 hour project of replacing engine mounts turned into a multi day event. I was able to get the 13mm offset wrench under the mount to hold the nut to undo the M8 bolts. Then things went south as my driver side mount M12 bolt was seized up. This bent the bar pretty bad which meant I had to get a new bar (Rennline). To get the old bar out, I tried lowering the engine a little bit but that didn't work. I ended up removing the crossover pipe + muffler + rear tin to get the bar out and slip the new bar in. The engine needs to be lower than its typical resting position (by 2 inches or so) to get the rear tin out. So if someone just wanted to take the rear tin out, you would still need to unbolt the M12 engine mount bolts and lower the engine a little bit to take the tin out. Then I figured I powder coat the rear and side tins (not too hard to remove, 5 x M6 bolts for each) while I am at it. That turned out well. Cost me about $125. I replaced all the nuts and bolts with new hardware and used nickel anti seize on the M12 bolts and the muffler bolts. Thanks to everyone who responded in this thread. |
It's tricky, but you're on the right track. You can cut a wrench down to get it to fit or I used a mini 1/4" ratchet.
You should drop the engine a couple of inches by removing the center bolts for more clearance. |
Just wait until you have to install the nuts onto the M8 bolts with the new mounts. I taped a magnet onto my finger to hold the nut and washer, still took hours. I had to walk away, it was making me crazy....
http://forums.pelicanparts.com/uploa...1585969646.JPG |
I think I removed the engine tin at the back, cleaned it up while I was at it. I broke the crossbar and had to reinforce and re weld it!
Good news: I was able to wiggle the offset wrench in there to get the M8 bolts off.
Bad news: I have gotten myself into a sticky situation. While undoing the big M12 bolt on the driver's side mount, the crossmember bent a little bit on that side. The passenger side bolt came off much easier. I unbolted the crossmember from the engine bracket thinking I can somehow wiggle the crossmember out the top. Nope, that was a dumb idea. Next idea was to remove the rear engine tin but the muffler is right up against it. Bolts are rusted so I sprayed some PB blaster and I am going to let it sit overnight before unbolt the muffler. Any advice would be appreciated. How can I get the crossmember out without doing an engine drop? The damn engine bracket gives no wiggle room. Heeeelppppppppppp. Assuming I am able to get it out, should I unbend the OEM one? Order a replacement OEM? Order a Rennline? |
Don't worry about bending it. It's flexible. In fact, I had to bend mine slightly for the drivers side M12 to fit in the hole.
Have you tried lowering the engine a small bit with your jack? Should give you some more space to work.
I did my '89 and it was a it of a pain but not too bad, getting them out was no problem. The car is up on jackstands? Just support the engine with your floor jack and let it drop down about 2" or so. The biggest pita was the nuts for the mounting bolts. I taped it to the end of my finger and then used a small wrench to hold in place for torquing down. 65ft/lbs for the centre bolt and 18ft/lbs for the outters...antiseize for the cente.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/27-Motor_Tranny_Mounts/27-Motor_Tranny_Mounts.htm |
Don't forget that when you install, leave all nuts and bolts loose. Tighten/torque the large main bolts first, then tighten the small retaining nuts/bolts last. This allows any pre-loads in the system to be eliminated.
I was hoping I can drop the engine 2 inches to get old bar out but engine doesn't want to go down easily. There's a bolt coming out of the AC compressor that will get stuck over the right engine mount area.
I am also not sure if I need to follow a different set of instructions if I proceed in the direction of lowering engine. Treat me like an idiot. Don't assume anything :-) |
To lower the engine, put a good jack under the center of the engine (to the rear), with a block of wood or similar to help distribute the load. Jack it up a little, remove the two main engine mount bolts, then lower the 2-3". Check carefully around the rear so there is no interference. |
Update 3. Got a chance to work on it some more today.
crosspipe came off easily. in preparation of taking off muffler bolts, i have been spraying them with "Liquid wrench" over the last few days. it worked. got the 3 muffler bolts + 2 strap bolts without any major issues. one of the strap bolts was slightly seized up but it eventually gave away. with crosspipe and muffler out of the way, the rear engine tin easily out (this was my 2nd fear..if this tin didn't come out, i would need to resort to lowering the engine). with the tin out, BAR IS OUT! that's where I stopped since I need to get new hardware. don't want to reuse any of the nuts and bolts. question: the muffler strap nut has some rust, should I order new straps (obviously not new OEM since they are 4 million dollars each)? http://forums.pelicanparts.com/uploa...1586634021.jpg Rennline bar left vs. oem bar. notice how much the end is twisted. very close to snapping at weld point. http://forums.pelicanparts.com/uploa...1586634021.jpg what was removed so far: http://forums.pelicanparts.com/uploa...1586634021.jpg seized up bolt! http://forums.pelicanparts.com/uploa...1586634021.jpg left to right: Engine mount bolts, enginer carrier bolt, engine tin bolt, muffler bolt, muffler strap hex bolt http://forums.pelicanparts.com/uploa...1586634576.jpg |
Due to a lack of any counterholding surfaces when tightening/loosening the bolt, the engine mount or cross bar (proper factory name = bracket) may eventually fail from metal fatigue - that corner of the engine will drop as far as gravity takes it, and if not caught in time, the other corner as well, then bigger problems.
The long term solution is to remove the internal threads from each end so the existing M12-1.5 x 95 bolt slides through the motor mount and bar end opening, then clamp together using a new M12 nut and washer (#s 11 and 13) - the same connection as in early 911 bars. You now have two hex shapes to rotate and counterhold to relieve stress on the engine mount bar. BTW, apply anti-seize onto threads and friction surfaces to reduce material corrosion and for more accurate tightening. http://forums.pelicanparts.com/uploa...1586648562.png http://forums.pelicanparts.com/uploa...1586648562.png Reinforcing the bar is an option as well. I've seen 964 engine mounts fail as well, but unsure of the cause of that. http://forums.pelicanparts.com/uploa...1586648562.jpg Sherwood |
I bought the rennline bar which seems to be much better made and fixes both issues you brought up. There's a nut (welded in) on the bottom and I forget the exact term, but reinforcement on the other side of the bar to avoid bending. |
I thought about trying this job 6 years ago.
Chickened out and never tried it. Looks like I made the right decision http://forums.pelicanparts.com/porsche-911-technical-forum/835453-questions-about-possible-motor-mount-diy.html |
You're the same guy who was talking about fabricating wrenches and dropping the engine for this job? LMAO.
If it were a 2, OP would not be making a thread about how FUBAR his project is. It is so confusing that I don't even know what went wrong. Multiple posters are talking about fabricating wrenches, taking hours to install a bolt, dropping the ****ing engine, removing engine tin (whatever that is), removing the exhaust, breaking crossbars, welding, etc. So, no, it's not a 2 when you're taking half the car apart |
on such a simple "20 minute repair"? You removed the small bolts. Then you tried to remove the large center bolt? It ended up bending the pointy end of the diamond shaped engine bracket? How hard was the M12 bolt to remove? Were you using a breaker bar? It's not easy to bend metal. Why did you try to remove the bracket? To be able to bend it back? What is the cross member? Why are you removing it? What is the cross pipe? Why are you removing it? |
Would using an impact wrench on the big center bolt help prevent bending the engine bracket sleeve?
How does one remove the threads anyway? |
Before OP's repair went off the rails, what effect would lowering the engine have?
How does that make this job easier? |
By fabricate a wrench, I mean cut one shorter for the tight space (that is if you don't have one that fits.) Dropping the engine an inch or so to get clearance for the engine mount nuts is not difficult. The OP is having lots of problems, partially related to a crossbar, possibly because he's creating more work for himself. It's really a simple job, no need to weld, remove engine tins, or exhaust. Of course if something is bent or broken it becomes exponentially more difficult, but a simple engine mount swap is just that, simple. |
You have to support the engine anyways, so just lower it a little. |
When I was researching this repair 6 years ago, someone posted this.
It sounds like OP removed the bolts in the wrong order? Why would this matter? How can the small bolts stop the bracket sleeve from twisting??? Quote:
As for your first question about lubing the threads, yes. However, the metal surrounding that end piece remains stressed by loosening and tightening torque. For thread removal, source a 12mm drill bit and run it through the threaded hole. The result is a clearance hole. There was another question in this or the previously referenced link about aligning parts to install the bolt. Whether there are threaded parts or not, insert an appropriately sized drift punch or equivalent (nail, Phillips screwdriver, chopstick, etc.) into the desired bolt path, then apply leverage to urge parts into close/closer alignment. If threaded parts aren’t involved, it’s just a matter of inserting the bolt, install washer and nut, then tighten the assembly. Apply torque, ideally, to the nut while holding the bolt head stationary. Since the fasteners may be undisturbed for years, I’d apply anti-seize to threads and frictional surfaces of the assembly. |
like salayc said, the steps simplified are jack up and support engine, remove 2 big bolts, remove 4 smaller bolts, swap mounts, replace and tighten bolts, lower jack. :) things that make it difficult or can go wrong are as follows: getting a wrench under the mount to hold the nut for the smaller 4 bolt. it's not roomy under there and you need to get clever. this was the original reason for the thread. then the next thing that can get difficult came to fruition. that is...big bolt does not want to come out. 700lb ft of torque from impact wrench..did not loosen it. 2ft breaker bar did..BUT then the next thing that can go wrong..did.. that is...crossmount bar twisted at the end. some people have reported that theirs snapped at the weld point. obviously at this point you need to get the bar out of the car, which is where i am/was. some people said do a partial drop to get the bar out. i was able to get mine out by removing muffler and rear tin. i am replacing the bar with a new rennline one that seems much better than the original bar. i am waiting for nuts/bolts to come in before i put everything back. i took the side tins out also and I am going to get all 3 tins powder coated while i have them out. hope this clarifies things |
I have heard of people talking about engine tins for years. I have no idea what they are. When you reinstall the tins and exhaust, can you take extensive photos? It's rare to ever see photos on this forum, and you appear to own and operate a camera.
Is it possible to spray liquid wrench into the M12 bolt hole from underneath the bracket?
http://forums.pelicanparts.com/uploads25/DSCN10011459910365.jpg And yes, I will try to take good pics during the reinstall. |
Finished the project last week. Updated original thread. Thanks everyone!
Here are some engine tin pics. I’m refreshing my suspension. In order to remove the troublesome trailing arm fasteners I decided to drop the drivetrain. While I was at it decided to clean up the engine tin work and engine mounting hardware.
http://forums.pelicanparts.com/uploa...1588126326.jpg I’ll post more as I get them installed. I came to this thread in search of the engine cross member fit up relative to the large rear engine tin. Kind of confusing. It’s been months since I dropped the motor and my memory is short. |
http://forums.pelicanparts.com/uploa...1588133211.jpg
http://forums.pelicanparts.com/uploa...1588133290.jpg The fussy rear tins. These were taken a while back before powder coating. |
Wow, that's clean! Thanks
| All times are GMT -8. The time now is 08:33 AM. |
