-   -   No high or low beam? Switch on column? (http://forums.pelicanparts.com/porsche-911-technical-forum/1056973-no-high-low-beam-switch-column.html)
dyount 04-04-2020 06:45 PM
I somehow lost both high and low while turning with signal on and trying to go from high to low beam. Quick and dirty is this just a new signal/high/low switch replacement? ( if removing the steering wheel etc is simple of course)
2jmotorsports 04-04-2020 11:16 PM
This is a new blinker stalk replacement although you could try this thread which just bends the headlight contacts to see if that takes care of your problem first.
