Lash
Replaced the bushings in the front torsion bar/control arm assembly's. I had previously replaced the front Bilstein shock inserts. When you have everything disassembled you take the time to clean and paint.
Now I will follow the procedure in adjusting the ride height and then have the front end aligned. 1980 911 SC Lash ![]() ![]() |
Hey, nice marmot.
Got a box of project parts from Pelican late last week. First up was installing the Eibach sway bar kit.
![]() Really nice kit. I was really impressed with the drop links. ![]() There were only a couple of things that slowed the installation. 1) Removing the OE sway bar. You know when you read instructions and it says “simply remove the old part...” — yea, that’s when you know you’re screwed. ![]() 2) The Eibach instructions have plenty of pictures but they are black and white and the contrast is was dark. It was a little difficult to figure out the orientation of the pictures and what I was looking at. It was also a little hard to figure out what angle the pictures were taken from and which side. I think a simple illustration of a cross-section along the front wheel axis and a top down view would’ve been much simpler. And add some labels. I didn’t look but if there are color pictures on their website I would suggest using that instead of the printed ones that came in the box. Had a quick test drive and I’m very happy. I started with the softest (safest) settings. There is slightly noticeable increase is transmitted NVH but not bad at all. The car feels much more stable in transition. Really happy with the purchase. Hoping to get some more wheel time this week.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 04-27-2020 at 10:43 AM.. |
Hooters
Well, my plan was to replace the US side marker lamps in the front bumper with the R.O.W. impact strips. Since the bumper had to come off to do this, figured that I should clean up my horns while I had access.
Before: ![]() After: ![]() The lamps aren't finished yet as the bumper is still out and I have decided to redo the rear tail lamps while I have some extra time. |
Lash
PatrickM
What year is your Porsche? Is that an aftermarket oil cooler? Lash |
Rebuilt the pedal assembly for my 1971 Targa. Cleaned and repainted everything. Replaced the old nylon bushings with new bronze bushings. New rubber brake lever stop and pedal pads.
The big surprise was the clevis fork that connects the clutch pedal lever to the clutch cable had been broken and JB Welded at some point and the clevis pin was zip-tied on! I can’t believe that was all that was keeping the clutch cable connected. Replaced with a new clevis fork and clevis pin. Really tough getting hands in the tunnel to do that but definitely worth the effort. ![]() ![]() ![]()
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
1984-911 M491
Getting the Seven sorted for spring.
1984-911 TLC......SOLD |
Rescuer of old cars
Got it back from the painter in mid-February. Just in time for things to start shutting down. But there are no viruses in my garage. Just wrapping up a few final details now.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s 1972 911T coupe Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Formerly known as Syzygy
It's often referred to as a Jailbird cooler.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 05-02-2020 at 10:20 PM.. |
Nice work on the 911/356 install. I did this a few years ago on a 57 coupe.
Mark Jung Bend, OR MFI Werks.com |
Cleaned out the engine bay by doing the heater backdate. Nice to have easy access to the forward corners of the compartment.
![]() ![]() I’d like to get rid of the fan motor bracket but it has a few other things attached to it. I will leave it for now. ![]() Next up will be to remove the cruise control system. It does not work and I would not use it anyway. |
Lash
Modeled up the fire extinguisher in CAD and designed a custom bracket for the seat mounts that came with the BF Torino bucket seats. I made three versions of the bracket, regular, light-weight, and ultra light weight. Obviously went with the ultra light weight one. Have two left over if anyone is interested.
Suspension re-do; bushings, ball joints, turbo tie rods, re-build steering box, bearings, clutch cable, e-brake cables, clutch, new flywheel, alloy front S brakes, rotors, plate, tumble, re-build, all new or re-built parts except shocks (New Von shocks were on the car)
Lawrence - Euro '78 911 SC Targa Fern Green |
Dial 911
![]() Quote:
BTW...Where did you purchase the spark plug hold down brackets?
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Racer
I bought the spark plug retainers from Sierra Madre Collection. For the CoP coil sticks, I needed standoffs for the retainers and I had to customize the bend and add a twist to get the best fit. That worked out as the Rennline valve covers don’t work well with retainers in general.
Scott Winders PCA GT-3R #3 Last edited by winders; 05-08-2020 at 09:16 AM.. |
Dial 911
Nice!!!
Changed the center insert of my seats, never done this before but pleased with the result
I restored these 15” fuchs to RSR finish myself and pulled my motor today. 3.2SS time. Stay at home in LA is sticking around for a while so may as well rebuild now.
1982 911 SC Targa - Guards Red 1986 944 Turbo - Zermatt Silver ZeroFuchsGiven.com #ZeroFuchsGiven |
Nice work on the refinished Fuchs. This is a great thread with such a WIDE variety of pleasant things to look at and drool over! A lot of us have gotten quite a bit done in the shop and around the house these past few months.
Thread Tools | |
Rate This Thread | |
