-   -   Porsche 911 Dyno Documentation Project... (http://forums.pelicanparts.com/porsche-911-technical-forum/105736-porsche-911-dyno-documentation-project.html)
Wayne 962 04-08-2003 09:01 PM
It was recently suggested to me that dyno charts on different engines should have been included in the new book. While this was impossible due to space limitations, I can post them on the website.
So, I would like to start an "open-source" project where you guys donate copies of your dyno run, and post them to the website. Maybe we can start a thread here where you post the dyno chart and then give the characteristics of your engine:
- case
- crank
- rods
- piston/cylinders
- cams
- Fuel System
- Compression ratio
- Normally aspirated or turbo
- Boost / size of turbo
- Max HP
- Max Torque
Sound like a good idea? There must be loads of people with dyno reports out there...
-Wayne
Yargk 04-08-2003 09:09 PM
Excellent idea, though Juan would probably be updating weekly...
Tim Walsh 04-08-2003 09:09 PM
ooo I like it. If/When I get mine done I'll gladly donate it.
Tim Walsh 04-08-2003 09:28 PM
well I'm sure if he had the time/money he'd do it daily :D
CamB 04-08-2003 11:06 PM
Short Stroke 3.2
Case - SC
Crank - SC
Rods - SC
Piston/cylinders - Mahle, cutouts for up to RSR cams, 98mm for 3,164cc
Cams - Early 911S grind
Heads - Either 930 or SC, ported, converted to twin plug (with 964 distributor)
Fuel System - MFI throttle bodies, bored to 40mm, converted to EFI injectors (944 Turbo), MoTeC 3D injection and ignition
Exhaust - SSIs with standard 2 in 1 out banana muffler
Compression ratio - 10.3:1
Normally aspirated or turbo - Normally aspirated
Boost / size of turbo - NA
Max HP (flywheel est) - 273ps at 6220rpm – 270hp, or 245hp at the wheels
Max Torque - 231 ftlb at 5100rpm (not shown)
Dyno - Dynapack hub dyno (1.1x transmission correction used)
http://forums.pelicanparts.com/uploa...hp_hp_only.jpg
The 2.0 it replaced
Case - '69 2.0
Crank - '69 2.0 911T
Rods - '69 2.0 911T
Piston/cylinders - '69 2.0 911T
Cams - Apparently they were E cams
Heads - '69 2.0 911T
Fuel System - Webers
Exhaust - factory rusty heat exchangers, 2 in 1 out banana muffler
Compression ratio - ??? about 8.6:1 I think
Max HP flywheel - 122hp at about 6000rpm - about 108hp at the wheels
Max Torque - don't know
Dyno - Bosch rolling road (transmission loss measured by coastdown at 11.5%)
http://forums.pelicanparts.com/uploads/dyno.jpg
smithH 04-08-2003 11:37 PM
Wayne,
If you set something up I am sure loads of people will put there figures up. I'll put mine up, 100% standard Euro but will be a bench mark. 105,000 miles no rebuild 215bhp at flywheel 205nm torque at ~5000, will have to scan the dyno print in.
regards
h
81 930 04-09-2003 12:42 AM
The following dyno run was made on my 1981 Euro 930 about a month-and-a-half ago. At the time, the car was stock with the exception of a 1 bar spring that had been shimmed to ~1.1 bar. As of today the car sports a new Tial wastegate @ 1.1 bar and a complete C2 intercooler setup. :) I also plan on adding a Blitz EBC and upgrading the turbocharger shortly. I will be dynoing the car again soon to compare to my baseline and post the results here.
Case - stock 930.60
Crank - stock 930
Rods - stock 930
Piston/cylinders - stock 930
Cams - stock 930
Heads - stock 930
Fuel System - K-Jetronic CIS
Exhaust - stock Euro, no cat or air pump
Compression ratio - stock 7.0:1
Normally aspirated or turbo - turbo
Boost / size of turbo - 1.1 bar on 100 octane / stock 3LDZ (K26)
Max RWHP - 312.7 @ 5200 RPM
Max RWTQ - 351.0 @ 4300 RPM
Dyno - DynoJet 248C
http://forums.pelicanparts.com/uploads/P2190021b.jpg
k9handler 04-09-2003 01:08 AM
Oh yeah....I will have to get her on a Dyno and see what she's got.
Wayne 962 04-09-2003 01:29 AM
Keep 'em coming, at least until I build some type of input wizard for the site...
-Wayne
Alan.UK 04-09-2003 05:02 AM
I will dig out the dyno plot for my 1971 2.2S and post it tomorrow.
Alan.uk
jyl 04-09-2003 05:34 AM
Wayne, consider asking what ignition system also? Would be interesting to know which of the modded cars are twin-plug, or Motec, or etc. Also, will responses be specific enough to determine displacement or should you ask for that too?
ttweed 04-09-2003 07:29 AM
Re: Porsche 911 Dyno Documentation Project...
Here's my 3.4 liter race motor:
- case: 3.2 Carrera
- crank: stock
- rods: Carrillo
- piston/cylinders: 98mm Mahle Sport
- cams: Webcam 131e grind
- Fuel System: PMO 50 carbs runnin on 98 octane race gas blend
- Compression ratio: 10.3:1
- Normally aspirated or turbo: normally aspirated
- Ignition: single plug with recurved Euro SC distributor
- Max HP: 280 at rear wheels
- Max Torque: 240 at rear wheels
http://members.rennlist.com/tweedt/3_4dyno.jpg
Here's the engine it replaced:
Bone Stock 1980 SC 3.0 with minor fuel enrichment/ignition mods and SSIs with sport muffler:
http://members.rennlist.com/tweedt/dyno.jpg
There are two pulls shown on this sheet- one before the fuel enrichment mods and one after. It gained almost 8 RWHP and 12 ft/lbs of torque from minor tuning tricks.
TT
ZCAT3 04-09-2003 08:52 AM
Wayne - I have a few dyno sheets I can send your way (one from my 930 and one from my 911). It what would be really great if you could come up with a way of grouping these so that people can search by engine type and modification. That way people could get an idea of what results the various upgrades can achieve. Also, baseline (pre-mod) dyno sheets are very hepful.
CamB 04-09-2003 02:59 PM
Good idea - I added that info to my post above.
dean 04-09-2003 03:33 PM
Wayne,
I don't know if I am stepping on toes but you might put a posting on C2turbo.com. They have a bunch of dyno postings on that site
Bill Verburg 04-09-2003 03:45 PM
Here is an example of a nicely done table of dyno runs. Concise, comprehensive, easily read, links to charts might be a nice +
Dr.-Ing. Mario Schacht
Eric86Red911 04-09-2003 04:55 PM
Wayne-
If you could standardize the inputs I'd volunteer to take the compiled data and do a statistical analysis. It would allow one to say things like "X option adds 3 hp, while Y option adds 5 hp."
With such an analysis, most inputs would be best as Yes/No responses, such as Factory or Pre-80s (?) Heat Exchangers. The fewer inputs the better. The downside is that certain data is not used, such as component manufacturer, but hey that's life.
Eric
Turbodrvn 04-09-2003 05:16 PM
Excellent idea and we're definitely working on it, Wayne!
The Chicagoland crew is working on some upcoming dyno sessions/events (hopefully within the next few weeks or within the next month)
We'll keep you all posted.
Ahmed "Alcrazy" - Yes, I'm all crazy about "turbodriven" cars!
'76 Porsche 930
'87 Buick Grand National
'92 Mitsubishi 3000GT VR4
All 3 heavily modded.
'02 Volvo S60 T5 (of course it's also a turbo!). Still a virgin......no mods......for now........ ;)
rrcrawford70s 04-10-2003 10:32 AM
Dyno Shop for group rates??
My 70 S now has a 2.7 RS Spec with MFI. I have always wanted to put it on a Dyno and see what the real HP is. I am sure many Pelicanites feel the same. I know the books state 210 hp. What is it REALLY?
Anyone have connections to a So. Cal. shop to help us ALL out? Maybe give group rates and pass the info to Wayne?
RickM 04-10-2003 12:24 PM
Wow, this is great....can wait to see what works and what doesn't work on our engines.
jluetjen 04-10-2003 06:41 PM
Wayne, in broad terms you also will need to know what the intake port diameter is. This will have a large inpact on the charactoristics of the cam and the resulting torque curve.
CJ 04-11-2003 02:35 PM
If my 911 is back together, I may be interested in the Chicago dyno event. Keep me posted.
GeorgeM 04-12-2003 05:38 AM
'89 Carrera Coupe w/ 120,000 original miles.
Stock internals
SSIs
Monty single out muffler
K&N w/drilled airbox
Custom chip by SteveW
http://forums.pelicanparts.com/uploads/2002 Dyno B.JPG
