Suggestions on putting body on rollers?
I'm curious if there is something out there that I could mount my G-body to a set of cheap rollers?
I'd like to completely dismantle the suspension, and then put the car up on a flatbed to take to a body shop.
Does Harbor Freight sell something cheap? (a couple hundred USD)
All I need is something to let me roll the car around and get it rolled up a flatbed ramp on a tow truck.
Thanks!!
1987 Porsche 911 Carrera Coupe
Old 02-28-2020, 08:52 AM
I just built my own....like $50 in casters and $50 in steel tubing and an afternoon with the welder.....
Dennis
Old 02-28-2020, 09:05 AM
I don't have a welder.. or know how to use one...
Would prefer something that just bolts onto the frame... or at the very least, something that can at least allow the body to rest on it properly.
Old 02-28-2020, 09:18 AM
Troll Hunter
I don't weld either, but my neighbor does. Bought some HD casters, gave him some measurements and where to drill the frame holes and $100 later, had this. It fit perfectly on my BMW and served the exact purpose you're looking for.
After I was done, I sold it for cost to another 2002 guy.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 02-28-2020, 09:28 AM
Dave O
I saw somewhere a version that was done in wood and was plenty sturdy. Possibly a Pelican post.
Dave O
1977 911 Carrera 3.0 Targa (Minerva Blue)
1987 VW Vanagon Westy w/ 2002 Subaru EJ25
Old 02-28-2020, 09:35 AM
Bli8's Avatar
I had Harbor Freight dollies and leftover wood beam and jerry rig this for the time being.
Not showing in the pictures, but I screwed jacking pucks (for body seams) into the wood and wood into the dolly.
Bruce - Socal
'76 912e (e for electric, thus not 912E) Emerald Green project car
'19 GT3 RS Lizard Green track car
'19 Carrera T Carrera White family car
Old 02-28-2020, 09:46 AM
The 9 Store
wood
All used parts sold as is.
Old 02-28-2020, 12:16 PM
Rodney Nelson's Avatar
I made mine out of wood too. Super easy. Mine is very simple made out of 4x4s, 2x4s, and Harbor Freight locking casters, and Bolts. Just figure out the dimensions and have Home Depot cut the wood for you, so when you get back home you are just drilling holes and bolting everything together. It is not bolted onto the body, I just used straps.
Roller:
On the way to the stripper:
On the way back home:
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 02-28-2020, 01:50 PM
What were you measuring? I could probably do that, but wasn't sure WHERE under the body I should be setting the body on.. the concern is I don't know where the center of gravity is on the body to measure correctly.
Old 02-28-2020, 02:01 PM
Your 87 will have 4 jacking pad locations under the body at each end of the rockers.
Lifting Points
Last edited by HaroldMHedge; 02-28-2020 at 02:25 PM.. Reason: Add link for lifting points
Old 02-28-2020, 02:21 PM
Mr.Anderson
Stoddard makes a car dolly. A little pricy if you have just one project but if you are like me
I will always have some project car . It Will work on anything from the 356 up to a 1989 not 11. Also has tiedown points to secure the dolly if you move it on a trailer to a paint shop.
https://www.*************/Werkstatte/newcardolly1/
Old 02-28-2020, 09:15 PM
Almost Banned Once
sc_rufctr's Avatar
There's some great ideas in this thread but I like Magnus Walker's solution for simplicity and safety.
(3 contact points means it would be stable on uneven ground but as always be careful.)
I also like this one.
- Peter
Old 02-28-2020, 09:54 PM
HI Trackrat,
As someone else said my measuring points were simply where the jacking points are, which is simply all four corners of the pan. For stability instead of points that it sits on I used a 4x4 that goes across the body left to right. It is simple just sitting on there and it is very stable even when I take off the straps. My car is still on this dolly for over a year as i work on it.
Good luck!
Rodney
Old 02-29-2020, 08:03 AM
Dennis
Do you have dimensions available? I like the idea of 4 points of contact. I was thinking that it could make life easier as well when doing the engine re-installation to be able to fit the quickjacks under the crossbars that the casters are bolted to.
Old 04-10-2020, 11:18 AM
