901 flange-driveshaft combination?
Hello to everyone,
I'm rebuilding an old 901 gearbox that came from a yard and both output flanges of the diff. are missing.
I have also got two driveshafts with the gearbox, that look quite shot.
They are the 4 bolt and 2 dowel kind.
I've been looking around (in Spain we have no PelicanParts sadly) I have found that compatible CV are made by various manufacturers: SKF, Mapco and GKN.
I know SKF are one of the best in bearings: VKJA 8829 (51€)
GKN seems to be Lobro some how (is this correct?) GKN - 21897 (50€)
Mapco im not sure if they're good quality, they are cheap and look exactly like the original with that brass finish. MAPCO - 16998 (37€)
so it would be an easy fix, buying 4 CV and attaching to the original shaft
Here comes the question, as I have to get buy a pair of output flages, and these CV seem to belong to a later model (2.7 or SC ?) should I get the later flanges?
Or earlier CV?
Thanks for your help!
Old 04-14-2020, 10:42 AM
Under the radar
Trackrash's Avatar
Post the number stamped on the bottom of the trans.
If the trans is a '69 up to '71 the 108mm four bolt trans axle flange is what you want. They were used from '69 to ~'75. At '75 1/2 Porsche changed to the 100mm 6 bolt CVs, which I don't think is what you want.
Have you seen this thread? 915 differences?
This also has some good info. 83 3.0L Engine & Trans Swap to 85 3.2L Engine & Trans - Axle Options
Here is what I know.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-14-2020, 01:09 PM
Fantastic threads Gordon. Thanks.
I've learned I have to check my diff. and see what kind of splines it has.
I was also wondering that a custom made gearbox mount shouldn't be too difficult to build and there it appeared in the thread. This forum is just amazing.
The numbers on my gearbox are: 901/13 _ _ 719 4906
The CV's I have do not match the chart
Mine are 4 bolt, 108, 32, but tommorrow I'll double check and mesure the axle too
I don't know if this complete driveshaft will fit my 1970 2.2t in lenght, I see now there are many different lengths.
Old 04-14-2020, 03:59 PM
Your 108mm 4 bolt CVs and axles should bolt right up to the 911 2.2T stub axle. The flange swap is what 914 4 to 6 conversion people do all the time, but those flanges are now more money than they used to be. Make sure you don't buy the Sportomatic flange because they are different.
Old 04-14-2020, 05:23 PM
Thanks Roblav for your tips
Kium
2.2T in bits...
Old 04-15-2020, 02:00 AM
