What is this connector?
I have one on each side of the front trunk but they are disconnected. I tend to think they may be the wires to my power mirrors since the mirrors are disconnected but Im not sure.
Old 04-09-2020, 10:49 PM
Old 04-09-2020, 10:50 PM
Power mirrors
Old 04-10-2020, 05:19 AM
wareaglescott's Avatar
yep mirrors
Old 04-10-2020, 07:00 AM
Ok, so I assume I am missing part of the harness then. Where do those two plugs connect to?
Old 04-10-2020, 07:04 AM
Kroon Wire Harnesses
mirrors
These plugs connect to the following looms:
driver side: 911 612 165 01
https://www.kroonwireharnesses.com/index.php?route=product/search&search=911%20612%20165%2001
and: passenger side 911 612 166 01
https://www.kroonwireharnesses.com/wire-harness-passenger-s-side?search=911%20612%20166%2001
Specialized in Classic Porsche electrics
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 04-10-2020, 10:59 AM
So is that wire, which looks like a male plug connector running to my mirrors or somewhere else? I tried to follow it on the drivers side and it looks like it joins into a bigger wire harness that is behind my dash and then continues on to the passenger side of the car.
Old 04-10-2020, 11:26 AM
mirrors
Yes, the harness you have will look like this one. part.no 911 612 164 03
https://www.kroonwireharnesses.com/wire-harness-lhd?search=911%20612%20164%2003
It runs from left to right and is supplied from the front fusebox.
Old 04-10-2020, 01:14 PM
So if I have that wire and I have the wire hanging from the mirrors inside the door then what parts am I missing?
I am missing the mirror switch over button under the dash and I have gotten in behind the gauges but cant seem to even find the connector to add the button.
If I have the wire int he picture then it looks like it should have that part of the cable but I cant find it.
Old 04-10-2020, 02:38 PM
If you follow the brown wires from the supply harness connected to the ground loop from the dashboard, you should be able to find the wires for the left/right selector switch. Three wire's, blue, green and black-yellow. Another wire (grey-green) is connected to your rear window heater switch.
Old 04-11-2020, 11:17 PM
Thanks and Ill take a look. My car is cabriolet so there is no rear window heater
Old 04-11-2020, 11:52 PM
There a rubber grommet with plug on each side up near firewall inside fender.
Old 04-12-2020, 06:16 AM
