-   -   Directional (Blinker) Issue-Help? (http://forums.pelicanparts.com/porsche-911-technical-forum/1057599-directional-blinker-issue-help.html)
High Hope 04-11-2020 09:35 AM
My blinkers were working correctly. Then I had my body shop install my H1s with newly painted trim rings. Then I installed the Pelican relay kit. I don't know if any of that is cause/effect, but now my right blinker works, F/R flash normally and the dashboard indicator is correct. The left blinkers both flash, but very dimly, and the dashboard indicator flashes in both directions, also very dimly.
Anyone have any ideas to offer?
Arne2 04-11-2020 10:44 AM
Sounds like a bad ground. Check the ground connection in the wiring to the left headlight and turn signal.
High Hope 04-12-2020 06:29 AM
Thanks @Arne2 . I assume that the headlight assembly has to come out?
