Yes, still parallel in your bottom picture. That is the point, of course that is in a perfect world.
Your bottom pic in your post above shows what happens when the tierod is not parallel to the lower control arm axis. Regardless, the only way to check and minimize bumpsteer is by measuring the toe change. FWIW, I spent months adjusting my tierod to be perfectly level to the ground on my 911 after I raised my spindles. It handled like a pig until I got out the strings and started actually measuring my toe change and adjusted my bumpsteer setup accordingly. |
Does anyone have experience with RSR struts? Is it true they come de-cambered? My shop seems to think so. I have not been able to get in touch with Steve W. (he sold them to me) but I know him, how he operates and he knew what was in/what was going in my car. I can't imagine he would sell me a set of struts that wouldn't work with my car. I will re-measure the hub distance and start playing with the bump/steer when I have a chance. Thanks! |
The more I think and look at this the more I am thinking it is a scrub angle issue. Look how far away from the center of the wheel the bottom of the strut is.
http://forums.pelicanparts.com/uploa...1587667783.jpg I can't jack the car up right now but I am thinking the car must have turbo hubs or something on it to push the wheel out that far. |
http://forums.pelicanparts.com/uploa...1587672045.gif a stock 911 w/ 7ET23.3 Fuchs has a s/r of 52.4mm per the factory the back space of that wheel is 121.1mm, so if you can measure the b/s of your wheel you can then determine s/r. b/s is defined here http://forums.pelicanparts.com/uploa...1587672285.gif |
I'm still confused by the hubs AFAIK there are only 4 different hubs that have ever been used on any 911 early cars used 37 or 40mm hubs, for ~'69 thru 89 they used 47mm hubs, in 1980 930 got 68mm hubs but they can't be used on a n/b because they push the wheel way too far out for regular 911 front fenders, before 1980 930 used 911 hubs |
I was hoping to find a hub issue, no such luck. I measured width from rotor to hub face (where wheel mounts), rotor width and back of rotor to chassis. Everything checks out compared to my Dad's car. I even measured the A-Arms to make sure mine hadn't been modified at some point.
Bill I keep referring to the following post. Quote:
I agree that the camber disparity needs to be addressed but I don't see how it would contribute to the kickback issue. I feel similarly about bump/steer. As far as I know, my car does not display the symptoms of a bump/steer issue. Am I wrong? Thanks |
Looks like you are running a pretty common, stock setup wrt hubs and wheels. 911 front suspension has scrub radius built into it by virtue of having strut suspension. You shouldn't have it any worse than other 911 drivers.
Given your setup, it doesn't necessarily look like bumpsteer should be a prominent issue either. Bumpsteer was my first thought in reading your first post. Trackrash's and Bill's comments are the generally accepted guidance, and you have the tie rod spacers which should help address bumpsteer. I'll only caution that bumpsteer, when you have it, can feel pretty unsettling and make the car feel unpredictable even when driving straight but especially when going over bumps. The car will dart around even with no steering wheel input. And the only way to really eliminate it is to measure it while exercising the suspension, and adjust the outer tie rod spacers accordingly. Sorry if I missed it, but can you describe the kickback in more detail? E.g. over bumps, when you're turning, etc. Is there slop in your steering by chance? |
Looking at that pic of your lower control arm and wheel, it definitely looks like you scrub radius is higher than stock.
If your wheels are 7” with ET 23, and your hubs are stock 47mm, then I would put money on your struts being decambered about 1 or 2 degrees. |
What is odd is that I don't think this "kickback" has a significant effect on the trajectory of the car. The car doesn't seem to really change much direction as a result. (or maybe it is just hard to tell) I do, however, think that it definitely unsettles the car and I also hate the way it feels. Quote:
Measuring, comparing and finding very similar measurements on my dad's car still doesn't explain why the wheels I had fit on his car and stuck out on mine. |
ttt
| All times are GMT -8. The time now is 06:35 PM. |
