What goes where
Can someone explain what hose goes at every number? Which one in particular goes to the air duct, but would like to know them all. Thanks
Old 04-12-2020, 05:28 AM
arbita1's Avatar
I have a later model so itís a bit different.
I can tell you
1 - heater hose to cabin vents.
3 - heater hose to Engine ducts.
4 - connects to muffler.
Not sure about 2.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-12-2020, 05:48 AM
I can tell you
Not sure about 2.
Thanks Matt. Where you write heater hose to engine ducts, is that also considered the air duct. I'm having trouble getting the thermostat in my mfi to shut off. I read in a post to make sure the hose connecting the air duct to heat exchanger has no holes in it. I'm trying to know which ones to look for, when I return to my mechanics shop tomorrow.
Old 04-12-2020, 06:14 AM
Number 2 is meant to supply heat for MFI
Dan Petchel
CarsincNJ.com
Targa top Restoration
Vintage parts
609 298 2277
carsinc@comcast.net
Old 04-12-2020, 07:47 AM
Rescuer of old cars
Arne2's Avatar
MFI thermostat feeds from the small elbow near #1. The larger #2 is also for MFI, for '72-73 cars (also RoW '74-on with 2.7 MFI) that have the big flapper valve for warm air intake.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-12-2020, 08:19 AM
Where I have circled yellow, what is that being connected to? Also, what exactly is number 2 connecting to? This is for a 69e, with stock 2.0 Thanks all!!!
Arne, just saw your post. If number 2 also goes to mfi, where does it connect to mfi? All I know of is the smaller supply line of warm air to the thermostat on mfi. Does number two connect to heat exchanger?
Appreciate any and all help.
Old 04-12-2020, 08:20 AM
Synchro Joe's Avatar
Maybe thjs will help:
MFI Heat Exchanger air tube question
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 04-12-2020, 09:33 AM
Originally Posted by Synchro Joe View Post
Helped a lot. Still wondering if my number 2 connects to heat exchanger?
Old 04-12-2020, 11:55 AM
Maybe some of these pics will help.
Driver side. this is the hose for the yellow circle.
Yellow circle, at the end of the hose
passenger side
topside
Ken
'69 911E
Old 04-15-2020, 06:16 PM
Thanks Ken
Old 04-16-2020, 01:07 PM
#2 is not a hose connection. The original boxes were called the street sweeper with an open grill forward bringing hot air to the box on the intake. Lots of dirt and plugged filters.
Bruce
Old 04-16-2020, 01:32 PM
Yellow circle is a hose connection on my '69 911E. From the heat exchanger to the tin work underneath is a heat resistant hose and from the tin work to the MFI on the top side is a paper hose.
From heat exchanger to tin work with heat resistant hose
underneath tin work. I think #2 is the large black duct in lower right corner of the pic
topside from tin work to MFI with aluminum lined paper hose
Why is hot air routed back into the shroud?
Ken
'69 911E
Old 04-16-2020, 06:00 PM
Bruce
Jeeze I'm an idiot for sure. Just dawned on me that I was getting #2 and yellow circle confused. Isn't #2 the large heat duct to the right in the middle pic above? To the left in bottom pic, large blak duct.
Ken
'69 911E
Old 04-16-2020, 06:05 PM
Great, and helpful pics guys!!
Old 04-17-2020, 03:48 AM
Ken, my mechanic is having a hard time setting fuel rich/lean mixture. He feels the engine is getting too much air. He's trying to dial it in on a dyno with air filter removed and velocity stacks exposed. It's a 69 911E. The mfi has just been rebuilt. Any suggestions as to why he can't get it set properly? I'm about out of patience with this shop.
Old 04-17-2020, 07:11 AM
Sorry I'm no help there.
I gave my engine to Storz to have thier way with it. Even he did not try to set the MFI; called in a pro, Mr. Eisenbud, in Denver. I've driven it 425 miles, it needs more adjusting. I've been led to believe dialing in the MFI is a rare art form.
Ken
'69 911E
Old 04-17-2020, 12:42 PM
Senior Advisor
James Brown's Avatar
yellow circled bung is for MFI warm up, #2 is from engine cooling fan too shrouds and cabin. There are SSI's for MFI and carbs/CIS models, make sure you get the correct one.
the MFI gets two hoses and the rest just one if that helps.
08 Cayenne Turbo
Old 04-17-2020, 01:19 PM
On a 69 MFI car you do not use #2 and the port circled in yellow. In fact that whole rear shell that covers the 3 pipes exhaust can be cut off to achieve the stock look. It seems Dansk only makes one SSI to cover several years. Have your mechanic compare it to your existing one. He’ll know what to do.
Old 04-18-2020, 05:01 PM
