7783911's Avatar
Heavy Gurgling on deceleration
I ve noticed of late that if I decelerate in gear (generally let off the gas above 300 rpm) I am getting a lot of burble from the exhaust, more then I ve noticed before. I know the exhaust system is buttoned up tight so need some advice where to look next. Mind you its not a back fire but a constant burble that is just louder then before
Its a 77 Targa with 83 SC engine
1 had a loose fitting injector sleeve in one cylinder which I reseated (the metal fuel line was pulling it upward) but I am not yet convinced it 100% airtight...could this result in poor fuel burning and thus the excessive decel noise?
I could test by picking up a new o ring for the sleeve and redoing that one, I guess too that checking/replacing the plug as it may be fouled as a result of poor ignition?
I ve looked through for the usual suspects like air leaks but nothing to be found and other then on decel, it runs and idles very well.
anywhere else I should be looking?
Bob
Old 08-03-2021, 01:41 PM
7783911's Avatar
nobody has an opinion?
could a loose air filter cover be the source of the issue?
Old 08-04-2021, 05:24 PM
Still here
pmax's Avatar
Some folks pay extra for heavy gurgling
Just sayin' ...
Having said that, decel valve, assuming the transplant has one ?
Old 08-04-2021, 06:18 PM
could be a number of things. From an overly rich condition. Decel valve allows more air compensating for that. But if its working then possibly a leaky injector? I dont think air leaks would cause gurgling but could be wrong. Is there a cold start valve on these I forget. Maybe try leaning it out a hair and see what it does.
Old 08-04-2021, 06:39 PM
7783911's Avatar
everything suggested check by my porsche specialist including running a smoke test..all good. Adjusted fuel mixture a minute amount but they feel that its perhaps a baffle in the exhaust that may have reached its end. I will leave for now and start to consider a new exhaust (2 in 1 out) that is less sporty (aka loud). Any suggestions, its an 83 sc engine, i love the after market units but they all seam geared to louder sporty sounds verus a little more sedate i am seeking
Old 08-13-2021, 06:40 AM
I'm good with tools.
AG81's Avatar
Please send extra gurgle to me....
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 08-13-2021, 10:53 AM
New-ish 911SC Targa Owner
pampadori's Avatar
One of the symptoms I had when my CIS airbox developed a crack was some fun exhaust gurgles. It got worse and worse until idle was not steady.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 08-13-2021, 11:57 AM
I was looking for the same in a muffler, my research lead me to Monty. I just installed SSIs and a 2 in 1 out Monty muffler (model M21) on my '79 SC. Very refined sound, no drone or resonance at all. Very sedate from the driver's seat, especially on cruise. It has a bit of a growl on throttle, but again not obnoxious in the cabin. It still sounds like a Porsche to me, I find some of the loud ones sound more like a muscle car. Very happy.
1979 SC Coupe (Sunroof Delete)
Old 08-13-2021, 12:13 PM
7783911's Avatar
ross
PM sent
Old 08-14-2021, 04:26 AM
PM answered
Ross
Old 08-21-2021, 01:31 AM
Tags
i did
