RPM Instrument Jumping on cold startup
Hi all,
I'm experiencing a strange problem I can't fix. On cold startups (Car is in the garage for some days) I see RPM instrument jumping (it sometimes read 0 RPM!!) even if the engine RPM are steady. Points has been replaced 1000 KM ago. They still seems new and dwell (measured when the engine is warm) is in spec. The strange problem is that once engine become warm or after some minutes of driving the problem disappear. Here is a video. Please note that at 30 sec I gently pressed the gas pedal. https://youtu.be/BGvur9xP_48 P.S: Car is a 1973 T with Zenith so it has no WUR
911 2.4T from 1973 Gemini Metallic Blue Last edited by fizeus; 04-12-2020 at 04:51 PM.. |
PRO Motorsports
Recheck the point gap, and contact cleanliness.
Put a voltmeter on the battery to check charging voltage when you start it cold. Check the connections at the distributor for the tack and points wire junction, as well as the coil trigger and ground connections. I’ve also seen a failing coil cause this, but it’s usually when hot, not cold. Finally, it may be the tach itself.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
My 1978 SC had a wildly fluctuating rpm gauge until I read on this forum that it could be the voltage regulator. Confirmed by fitting a digital voltmeter to the cigarette lighter which showed up to 18 volts when needle swinging. New voltage regulator fixed it.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Thank you for the suggestions ... connections seem good also distributor points has been cleaned with lacquer thinner and some paper.
I was already looking at the VR .... On startups it seems to be a little out of specs and also while driving it continuously jump up to 15.5 Volts ... Is this value too high or can I consider it in specs ?
911 2.4T from 1973 Gemini Metallic Blue |
well? i would check your fuel mixture...1st..then your 15,5 is a little too much the max should really be 14,8....do you still have internal regulator or already external?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Ivan,
fuel mixture should be ok according to the Gunson ColorTune even if I think it's still a little bit rich. My VR is an original external Marchal regulator. I bought a new BERU GER 024 but I haven't still installed due to the modifications needed to the fuse box panel (beer VR has different mount screws)... to be honest I was looking for a used/damaged Marchal voltage regulator box to "hide in" the Beru VR box. Suggestions? Here the BERU VR photos
I wouldn't be surprised if you find out that the board in the tach is causing this. I've rebuilt several of them and there are capacitors, transistors and diodes in these old tachs that go bad and can cause this.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
