Luftgekühlt
Josh90's Avatar
Wiring of front turn signals
Hello everyone,
before going into details of my current issue and start with my first thread I would like to take the chance to introduce my self to the community.
My Name is Johannes, I'm 29 and from Munich, Germany. I'm working as in Program Manager in the automotive industry since 3 years. I'm passioned about cars since forever and bought my first 911SC from 79 right after university and take the chance to drive through the alps and Italy as much as possible
The car was a reimport from italy w/o any main issues. But the pre-owner did some strange reworks on the electricity and changed also other few things on the car.
During the Corona-Shutdown I'm now working on the electricity and I hope you guys are able to help me out.
The pre owner eliminated the wiring for the front turn signals and I try to restore that.
I need your help to understand how this wiring was placed in the car. I can't find the locations where the wiring was going through the body to the fenders.
Those are the pictures from my car and the possible locations. Pictures from your cars would help a lot. Thank you in advance.
Old 04-15-2020, 12:51 AM
Luftgekühlt
Josh90's Avatar
Hi guys,
I would really appreciate some pictures from you cars. This would help a lot.
Thanks ����
Old 04-16-2020, 12:15 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pictures.
All I have are the factory schematics.
It will be difficult to find pictures
as all of the wires are inside the bumper.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-16-2020, 12:22 PM
ROW '78 911 Targa
timmy2's Avatar
The signal wires are in the same harness that goes through the fender wall directly into the headlight buckets. There are normally 3 flat connectors inside the headlight bucket for the signal lamp wires to connect to. Then the signal and running light wires come out of the headlight bucket down into the bumper.
The holes for the lighting harnesses inside the trunk are further towards the front than your photos show.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-16-2020, 12:46 PM
ROW '78 911 Targa
timmy2's Avatar
Passenger side, you can see the horn wires going in, the headlight and signal wire harness goes in beside it.
Dennis
Old 04-16-2020, 01:31 PM
Luftgekühlt
Josh90's Avatar
Hi Timmy,
Thank you for sharing, but I’m referring to the turn signals in the side fenders. The ones you can see on the picture of my car.
Cheers
Johannes
Old 04-16-2020, 01:36 PM
Cory M's Avatar
Welcome to Pelican. I just had to fix my turn signal wiring and found the images in this thread to be very helpful:
Wiring harness to front turn signal/parking lamps - Question
Old 04-16-2020, 01:38 PM
Luftgekühlt
Josh90's Avatar
Hi Cory,
Thanks man. I guess we are talking about two different turn signals.
But I’m not sure if those were also part of US Models?!
Old 04-16-2020, 01:43 PM
Cory M's Avatar
Yeah those lights are not on the US models
Old 04-16-2020, 01:51 PM
ROW '78 911 Targa
timmy2's Avatar
Ok, I think those are only the side marker running lights for Europe. not turn signals that flash. 1980 and newer I believe. My ROW car is too old to have them...
Dennis
Old 04-16-2020, 03:29 PM
Cory M's Avatar
Assuming the turn signals are wired correctly and include the 3rd wire for the side markers, and they have the two metal spades on the back of the turn signal housing, you could run a pair of wires from those spades to the fender mounted marker lights. You could test it out just running the wire under the fender or with a test light, if it works it would probably be cleaner and more correct to route the wires into the trunk and back out to the fenders.
Old 04-16-2020, 08:32 PM
Cory M's Avatar
These are the spades or terminals I'm referring to on the housing:
If the signal housing only has 2 wires coming out of it and not 3 this likely won't work because the 3rd wire is for the marker lights.
Old 04-16-2020, 08:38 PM
Rescuer of old cars
Arne2's Avatar
Actually, the other way around. They are turn signal repeaters, not running lights. They flash with the signals. Required in Europe after a certain point, not sure when. RoW Porsches started getting them in '81. BMWs were a couple years later as my RoW '81 323i did not have them.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-17-2020, 07:41 AM
Luftgekühlt
Josh90's Avatar
Hi guys,
thanks to all of you
See attached the actual wiring.
Old 04-19-2020, 12:27 AM
ROW '78 911 Targa
timmy2's Avatar
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1979/wire-harness-direction-indicator-light
Looks like Gerald makes them. Perhaps he could help you with where they are routed.
Photo shows the grommets and that they connect directly to the fuse panel wiring, not the front signal lights.
Dennis
Old 04-19-2020, 08:35 AM
...now if only I could find the boots that cover those side marker lights, that'd be great. I have to add them to my European bound 911 and have all the parts.....except those boots and can't find them on PET...
Dennis
Old 05-04-2020, 11:13 AM
Rescuer of old cars
Arne2's Avatar
Dennis
Same light and boot was used on RoW Mk 2 Golf/Jetta. Might check with VW sources.
2018 718 Cayman 2.0
Old 05-04-2020, 11:25 AM
fallingat120mph's Avatar
Originally Posted by Josh90 View Post
Hi guys,
Did you ever finish this project? Am trying to figure out where the 'side markers' tie in to the car. Will be taking the fenders off soon and just wondering your outcome?
Not sure if my US spec car is prewired for these, or if there is a work around.
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-02-2023, 08:12 PM
Actually I will ask the forums.
For those out there that have removed the fenders for various projects are there connections under there for the side markers??? Looking at the harness I am ordering it seems like simple connectors....
Has anyone else installed these and have some insight?
I have spare fenders and this is a project I am trying to do. Just curious.
Any information is appreciated!
Thanks -
Erik
1986 911 Coupe
1986 911 Targa
Old 02-03-2023, 10:34 AM
My 964 has plugs for the repeaters toward corners by the fuse box. I have thought about adding the lights but I haven’t been brave enough to drill holes in my fenders. Also not sure if I need to pull the fenders to route the wires.
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 02-03-2023, 12:10 PM
