out date clutch release bearing
I have a 2.7 engine with a 915 clutch assembly and release bearing installed.
will be using a 901 trans and release bearing on this 915 pressure plate.
question
can I remove the 915 release bearing and use the 901 clutch release bearing and fork with the 901 tran with a 915 pressure plate ????
Old 04-14-2020, 11:49 AM
No. The 901 is a push clutch, 915 is a pull style. A 70/71 type 911 trans is basically a 901 that is set up to use a pull style 915 clutch. Different fork and cable setup. Maybe that's what you need.
206 637 4071
Old 04-14-2020, 12:08 PM
Under the radar
Trackrash's Avatar
What year trans? A '70-'71 trans will work with a 915 pressure plate. A '69 and older trans used a different flywheel and PP than the 915.
BTW, the '70-'71 trans requires a unique clutch disc as well as the throw out bearing, cable, and release arm.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-14-2020, 02:37 PM
the 901 is out of a 1968 911S. so I will need to change flywheel, pressure plate, clutch, and throw out bearing and fork???
can I use a 2L flywheel and cutch out of a 914 , 1973??
Old 04-14-2020, 04:39 PM
djpateman's Avatar
Yes, you really need to change everything. The 914 clutch is essentially the same as the early 2.0 911 clutch except for lower clamping force.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-14-2020, 04:45 PM
I give up. going to buy a 915 trans.
Old 04-16-2020, 10:04 AM
